Page 1 of 1
zms rotate patch
Posted: Tue Feb 20, 2007 1:07 pm
by acrid
i needed to rotate the zms streaming image, because my mobile has a resolution of 240x320 and i want to have it fullscreen
(see
http://support.yoics.com/viewtopic.php?t=22)
so i added another parameter to zms and used phils rotate function. no big thing, but might be useful.
the patch for 1.22.3 is available at:
http://www.liquid-co.de/pub/zm/patch/zms_rotate.patch
cheers,
tim
Posted: Tue Feb 20, 2007 1:35 pm
by MJN
I like the sound of this as I too occasionally access ZM via my PDA. Currently I'm rotating the screen every time but to not have to would obviously be a bonus.
I'm completely ignorant when it comes to patching so could you briefly summarise what I have to do to implement this? Also, can you confirm it only changes things when connecting via the PDA/mobile and not in 'normal' use? (I currently use the format=xhtml URL suffix when using the PDA if that's relevent)
Mathew
Posted: Wed Feb 21, 2007 11:12 am
by acrid
with the patch you are able to rotate a picture just for a single stream, and only the stream (not the webinterface picture, not the camera input).
e.g. you have
http://localhost/cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=50&maxfps=5&user=foo&pass=bar&rotate=90
(note the rotate option!)
which will result in a 90° rotated multipart jpeg stream. as is said, i use it with a small java application, which just pulls and displays the image. i avoid to rotate the image on the "thin-client".
if you want to give it a shot, you need to download the patch into the source directory where you are building zm from. then run
and configure, make.... as usual
maybe it would be useful to get access to the rotated image via the webinterface (i.e. for PDA users). could be a flag for each user: "degrees to rotate streams"
Posted: Wed Feb 21, 2007 12:04 pm
by MJN
Okay, I see. Thanks for the clarification. All I really need is a quick way to see a snapshot of the current camera view on my PDA so this will be ideal.
Will give it a try!
Mathew
no rotations needed?
Posted: Sat May 03, 2008 12:52 am
by acrid
is there a reason why this mini-feature didn't make its way into the code? i always have to force monex to patch it into the suse RPMs
my PDA cant rotate its screen. so if i use the PPC-Viewer - without rotating the picture - i have several black areas.
Posted: Mon May 05, 2008 7:23 pm
by zoneminder
1.23.3 came out in a bit of a hurry. I will have another look at this patch and if it presents no problems add it for the next release.
update needed
Posted: Wed May 07, 2008 9:29 am
by acrid
The patch won't work on 1.23.2
I need to make an update... Don't call use - we call you
New patch for 1.23.3
Posted: Thu May 15, 2008 9:54 am
by acrid
