XTAL problem
Dreamer
XTAL problem
Post by Dreamer »
I've just installed ZM on a old PC (Celeron 600 with a Haupaugge std card)and syslog is overflowing with the following;
Feb 25 21:57:03 webserver kernel: [ 7438.169002] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:03 webserver kernel: [ 7438.363098] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:03 webserver kernel: [ 7438.649199] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:03 webserver kernel: [ 7438.846556] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:04 webserver kernel: [ 7439.128724] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:04 webserver kernel: [ 7439.330320] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:04 webserver kernel: [ 7439.628481] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:04 webserver kernel: [ 7439.814060] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:05 webserver kernel: [ 7440.048321] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:05 webserver kernel: [ 7440.247549] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:05 webserver kernel: [ 7440.568242] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:05 webserver kernel: [ 7440.764813] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:06 webserver kernel: [ 7441.088034] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:06 webserver kernel: [ 7441.281598] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:06 webserver kernel: [ 7441.587854] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:06 webserver kernel: [ 7441.765797] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:07 webserver kernel: [ 7442.027518] bttv0: PLL can sleep, using XTAL (28636363).
Feb 25 21:57:07 webserver kernel: [ 7442.215525] bttv0: PLL: 28636363 => 35468950 .. ok
Feb 25 21:57:07 webserver kernel: [ 7442.527534] bttv0: PLL can sleep, using XTAL (28636363).
It wasn't being filled before ZM was installed; any ideas?
cordel
Post by cordel »
What distro?
uname -r
How did you configure the card?
dmesg |grep bttv
If you edited the mod file what did you add?
cat /etc/modprobe.conf |grep bttv
Dreamer
Post by Dreamer »
Ubuntu 6.10
2.6.17-11-server
dmesg | grep bttv gives pages of;
[ 8994.210968] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8994.453901] bttv0: PLL can sleep, using XTAL (28636363).
[ 8994.648243] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8994.933616] bttv0: PLL can sleep, using XTAL (28636363).
[ 8995.128051] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8995.433624] bttv0: PLL can sleep, using XTAL (28636363).
[ 8995.612139] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8995.853436] bttv0: PLL can sleep, using XTAL (28636363).
[ 8996.045267] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8996.333237] bttv0: PLL can sleep, using XTAL (28636363).
[ 8996.528990] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8996.833035] bttv0: PLL can sleep, using XTAL (28636363).
[ 8997.012599] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8997.252894] bttv0: PLL can sleep, using XTAL (28636363).
[ 8997.446156] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8997.732749] bttv0: PLL can sleep, using XTAL (28636363).
[ 8997.929863] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8998.232464] bttv0: PLL can sleep, using XTAL (28636363).
[ 8998.413428] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8998.652492] bttv0: PLL can sleep, using XTAL (28636363).
[ 8998.847062] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8999.132246] bttv0: PLL can sleep, using XTAL (28636363).
[ 8999.330660] bttv0: PLL: 28636363 => 35468950 .. ok
[ 8999.612120] bttv0: PLL can sleep, using XTAL (28636363).
[ 8999.830993] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9000.131906] bttv0: PLL can sleep, using XTAL (28636363).
[ 9000.331274] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9000.611691] bttv0: PLL can sleep, using XTAL (28636363).
[ 9000.831589] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9001.151432] bttv0: PLL can sleep, using XTAL (28636363).
[ 9001.331906] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9001.571374] bttv0: PLL can sleep, using XTAL (28636363).
[ 9001.765770] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9002.071204] bttv0: PLL can sleep, using XTAL (28636363).
[ 9002.249592] bttv0: PLL: 28636363 => 35468950 .. ok
[ 9002.491079] bttv0: PLL can sleep, using XTAL (28636363).
[ 9002.682816] bttv0: PLL: 28636363 => 35468950 .. ok
and not quite sure wher the modfile is now in Ubuntu 6.10;
cat /etc/modprobe.d/
aliases arch/ blacklist blacklist-modem blacklist-pata isapnp
alsa-base arch-aliases blacklist-framebuffer blacklist-oss blacklist-watchdog options
Dreamer
Post by Dreamer »
does anyone know what this means?
And why is it repeating several times a second?
Dreamer
Post by Dreamer »
Done a reformat, and this doesn't happen until ZM 1.22.3 is installed. Has no-one seen this before?
