debian install problems
I just did a fresh Debian system install. Followed the guide on the wiki pages. Viewing live images works fine, however when i try to view saved events or setup zones the image box shows the broken image link. Any ideas whats up with that? IS there some special permissions i must put on the archive directories ? thanks
Yes,
We're looking at your events dir (set in zm config page) and all the subdirs below.
Either change the owner to www-data and permissions to 755, or if you have closed access to your box, a 777 will definately work but isn't that secure.
Something like:
chmod -R 777 events
chown www-data.www-data events -R
Something like:
chmod -R 777 events
re
Salut!
y a-t il quelqu'un qui parle français
j ai quelque soucis apres l installation via les depots 'SID'
pas d'image (du tout) de ma webcam sous zm. alors que ça marchais avec installation
avec les sources(wiki);y a t-il des parametre à modifier sous etch a modifier apres installation avec APT-
SVP. MERCI
SVP. MERCI
