Page 1 of 1
Cambozola and zms
Posted: Tue Jul 15, 2003 2:54 am
by gardo
For some reason, Cambozola loads, but never displays anything. Right clicking brings up some status information. 0 FPS, and the correct address. I am running RH8, is there anything special I need todo to get zms to stream properly. Or, is there an easy way to turn on debug information, so I know zms is streaming, but Cambozola is choking?
Ryan
Re: Cambozola and zms
Posted: Tue Jul 15, 2003 9:33 am
by zoneminder
Hi Ryan,
Do you know which version of Cambozola you are using? If you have a recet version I would recommend trying it with 0.22, which is available from the zoneminder.com in the downloads area. I've found this one to be the most reliable.
You can also check in /var/log/messages for any obvious errors or run zms from the command check it is outputting correctly. Also you might want to try using Netscape or Mozilla to try the streaming without Cambozola and of course make sure that your cgi setup is correct in your web server.
Phil,
Posted: Tue Jul 15, 2003 9:12 pm
by gardo
I am using 0.22 downloaded from your site. I don't see any reference to it in my /var/log/httpd/access_log or /var/log/httpd/error_log. I don't think after it loads it is contacting my server. However, the IP address looks correct in the URL: string for cambozola. Also, I see zms running under 'top' when I don't have a streaming window open. I'm not sure what is going on here.
Ryan
Posted: Wed Jul 16, 2003 7:57 pm
by gardo
0.22 will never start the stream. However, when I upgrade to 0.34 it streams, but the images are all corrupt. When I go back to 0.22, the stream will not start.
Ryan
Posted: Fri Jul 18, 2003 10:33 am
by zoneminder
Hi Ryan,
I've not heard of any previous issues with v.22 of Cambozola, which browser are you trying it from? Do you get anything displayed at all?
Phil,
Posted: Tue Jul 22, 2003 12:07 pm
by igord
Same with me. WinXP IE6 0.22 - nothing, latest - corrupt images
Posted: Wed Jul 23, 2003 9:49 am
by eservaas
Try an other browser (IE6 doens not work with it but using galeon it works fine.
Does anybody has a suggestion getting it to work onder IE6 ?
Ed
Posted: Wed Jul 23, 2003 2:37 pm
by eservaas
YESS!!! It works now, the problem was mod_auth witch I have compiled with Apache, after changing the policy is works GREAT!
Good job!
