Page 1 of 1
Can't get shared memory id '7a6d2002
Posted: Tue Mar 06, 2007 10:13 pm
by breizhbug
I installed zm on Xubuntu following Debian faq in wiki.
Zm is started as a service and I can access to the http page.
I declared 2 axis cameras into and try to monitor them
I don't show image and don't understand why
There is no log files in var/log
here is a copy of tail on zm log files
Would you please help me
Pascal
==> /tmp/zmaudit.log <==
03/06/07 22:45:22.724887 zmaudit[16903].DBG [Found filesystem monitor '2']
03/06/07 22:45:22.725203 zmaudit[16903].DBG [Got 0 events]
06.03.2007 22:50:53.838584 zmaudit[17872].DBG [Found database monitor '1']
06.03.2007 22:50:53.839564 zmaudit[17872].DBG [Got 0 events]
06.03.2007 22:50:53.839683 zmaudit[17872].DBG [Found database monitor '2']
06.03.2007 22:50:53.840001 zmaudit[17872].DBG [Got 0 events]
06.03.2007 22:50:53.840476 zmaudit[17872].DBG [Found filesystem monitor '1']
06.03.2007 22:50:53.840656 zmaudit[17872].DBG [Got 0 events]
06.03.2007 22:50:53.840714 zmaudit[17872].DBG [Found filesystem monitor '2']
06.03.2007 22:50:53.840815 zmaudit[17872].DBG [Got 0 events]
==> /tmp/zmdc.log <==
06.03.2007 23:05:16.082673 zmdc[17817].INF ['zmc -m 2' starting at 07/03/06 23:05:16, pid = 18318]
06.03.2007 23:05:16.104770 zmdc[17817].ERR ['zmc -m 2' exited abnormally, exit status 255]
06.03.2007 23:05:26.439307 zmdc[17817].INF ['zmc -m 1' starting at 07/03/06 23:05:26, pid = 18320]
06.03.2007 23:05:26.456189 zmdc[17817].ERR ['zmc -m 1' exited abnormally, exit status 255]
06.03.2007 23:05:26.659706 zmdc[17817].INF ['zmc -m 2' starting at 07/03/06 23:05:26, pid = 18322]
06.03.2007 23:05:26.709599 zmdc[17817].ERR ['zmc -m 2' exited abnormally, exit status 255]
06.03.2007 23:05:37.040411 zmdc[17817].INF ['zmc -m 1' starting at 07/03/06 23:05:37, pid = 18324]
06.03.2007 23:05:37.078981 zmdc[17817].ERR ['zmc -m 1' exited abnormally, exit status 255]
06.03.2007 23:05:37.644081 zmdc[17817].INF ['zmc -m 2' starting at 07/03/06 23:05:37, pid = 18326]
06.03.2007 23:05:37.660379 zmdc[17817].ERR ['zmc -m 2' exited abnormally, exit status 255]
==> /tmp/zmfilter.log <==
06.03.2007 22:56:58.876789 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 22:57:58.879157 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 22:58:58.883310 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 22:59:58.886881 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 23:00:58.890862 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 23:01:58.902197 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 23:02:58.906106 zmfilter[17867].DBG [Reloading filters]
06.03.2007 23:02:58.907352 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 23:03:58.909742 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 23:04:58.930825 zmfilter[17867].DBG [Sleeping for 60 seconds]
==> /tmp/zmpkg.log <==
06.03.2007 21:43:39.378212 zmpkg[13900].INF [Command: start]
06.03.2007 21:46:42.529020 zmpkg[14083].INF [Command: stop]
06.03.2007 21:46:55.901630 zmpkg[14133].INF [Command: start]
06.03.2007 22:25:00.406710 zmpkg[16520].INF [Command: stop]
06.03.2007 22:25:13.525945 zmpkg[16572].INF [Command: start]
03/06/07 22:29:55.477110 zmpkg[16822].INF [Command: stop]
03/06/07 22:30:17.523759 zmpkg[16861].INF [Command: start]
06.03.2007 22:50:36.108773 zmpkg[17745].INF [Command: stop]
06.03.2007 22:50:48.081546 zmpkg[17797].INF [Command: start]
06.03.2007 22:51:06.183814 zmpkg[17901].INF [Command: start]
==> /tmp/zmupdate.log <==
06.03.2007 21:43:46.550809 zmupdate[13962].INF [Checking for updates]
06.03.2007 21:43:47.323523 zmupdate[13962].INF [Got version: '1.22.3']
==> /tmp/zmwatch.log <==
06.03.2007 23:05:26.465014 zmwatch[17877].INF ['zmc -m 1' starting at 07/03/06 23:05:26, pid = 18320]
06.03.2007 23:05:26.466048 zmwatch[17877].ERR [Can't get shared memory id '7a6d2002', 2: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:26.466240 zmwatch[17877].INF [Restarting capture daemon for 101, shared memory not valid]
06.03.2007 23:05:26.717368 zmwatch[17877].INF ['zmc -m 2' starting at 07/03/06 23:05:26, pid = 18322]
06.03.2007 23:05:36.729155 zmwatch[17877].ERR [Can't get shared memory id '7a6d2001', 1: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:36.730304 zmwatch[17877].INF [Restarting capture daemon for 207, shared memory not valid]
06.03.2007 23:05:37.216580 zmwatch[17877].INF ['zmc -m 1' starting at 07/03/06 23:05:37, pid = 18324]
06.03.2007 23:05:37.217720 zmwatch[17877].ERR [Can't get shared memory id '7a6d2002', 2: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:37.217960 zmwatch[17877].INF [Restarting capture daemon for 101, shared memory not valid]
06.03.2007 23:05:37.668385 zmwatch[17877].INF ['zmc -m 2' starting at 07/03/06 23:05:37, pid = 18326]
==> /var/log/messages <==
Mar 6 23:05:37 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 207, shared memory not valid]
Mar 6 23:05:37 Pascal5 zmdc[17817]: INF ['zmc -m 1' starting at 07/03/06 23:05:37, pid = 18324]
Mar 6 23:05:37 Pascal5 zmdc[18324]: INF ['zmc -m 1' started at 07/03/06 23:05:37]
Mar 6 23:05:37 Pascal5 zmc_m1[18324]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:05:37 Pascal5 zmwatch[17877]: INF ['zmc -m 1' starting at 07/03/06 23:05:37, pid = 18324]
Mar 6 23:05:37 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 101, shared memory not valid]
Mar 6 23:05:37 Pascal5 zmdc[18326]: INF ['zmc -m 2' started at 07/03/06 23:05:37]
Mar 6 23:05:37 Pascal5 zmdc[17817]: INF ['zmc -m 2' starting at 07/03/06 23:05:37, pid = 18326]
Mar 6 23:05:37 Pascal5 zmc_m2[18326]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:05:37 Pascal5 zmwatch[17877]: INF ['zmc -m 2' starting at 07/03/06 23:05:37, pid = 18326]
06.03.2007 23:05:47.673822 zmwatch[17877].ERR [Can't get shared memory id '7a6d2001', 1: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:47.674924 zmwatch[17877].INF [Restarting capture daemon for 207, shared memory not valid]
Mar 6 23:05:47 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 207, shared memory not valid]
06.03.2007 23:05:48.953768 zmdc[17817].INF ['zmc -m 1' starting at 07/03/06 23:05:48, pid = 18348]
06.03.2007 23:05:49.112220 zmdc[17817].ERR ['zmc -m 1' exited abnormally, exit status 255]
06.03.2007 23:05:49.172230 zmwatch[17877].INF ['zmc -m 1' starting at 07/03/06 23:05:48, pid = 18348]
06.03.2007 23:05:49.174257 zmwatch[17877].ERR [Can't get shared memory id '7a6d2002', 2: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:49.174877 zmwatch[17877].INF [Restarting capture daemon for 101, shared memory not valid]
Mar 6 23:05:49 Pascal5 zmdc[17817]: INF ['zmc -m 1' starting at 07/03/06 23:05:48, pid = 18348]
Mar 6 23:05:49 Pascal5 zmdc[18348]: INF ['zmc -m 1' started at 07/03/06 23:05:48]
Mar 6 23:05:49 Pascal5 zmc_m1[18348]: INF [Debug Level = 0, Debug Log = <none>]
06.03.2007 23:05:49.536784 zmdc[17817].INF ['zmc -m 2' starting at 07/03/06 23:05:49, pid = 18350]
06.03.2007 23:05:49.561474 zmdc[17817].ERR ['zmc -m 2' exited abnormally, exit status 255]
06.03.2007 23:05:49.570417 zmwatch[17877].INF ['zmc -m 2' starting at 07/03/06 23:05:49, pid = 18350]
Mar 6 23:05:49 Pascal5 zmwatch[17877]: INF ['zmc -m 1' starting at 07/03/06 23:05:48, pid = 18348]
Mar 6 23:05:49 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 101, shared memory not valid]
Mar 6 23:05:49 Pascal5 zmdc[17817]: INF ['zmc -m 2' starting at 07/03/06 23:05:49, pid = 18350]
Mar 6 23:05:49 Pascal5 zmdc[18350]: INF ['zmc -m 2' started at 07/03/06 23:05:49]
Mar 6 23:05:49 Pascal5 zmc_m2[18350]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:05:49 Pascal5 zmwatch[17877]: INF ['zmc -m 2' starting at 07/03/06 23:05:49, pid = 18350]
06.03.2007 23:05:53.845207 zmaudit[17872].DBG [Found database monitor '1']
06.03.2007 23:05:53.846089 zmaudit[17872].DBG [Got 0 events]
06.03.2007 23:05:53.846202 zmaudit[17872].DBG [Found database monitor '2']
06.03.2007 23:05:53.846494 zmaudit[17872].DBG [Got 0 events]
06.03.2007 23:05:53.868917 zmaudit[17872].DBG [Found filesystem monitor '1']
06.03.2007 23:05:53.869576 zmaudit[17872].DBG [Got 0 events]
06.03.2007 23:05:53.869641 zmaudit[17872].DBG [Found filesystem monitor '2']
06.03.2007 23:05:53.869993 zmaudit[17872].DBG [Got 0 events]
06.03.2007 23:05:58.933271 zmfilter[17867].DBG [Sleeping for 60 seconds]
06.03.2007 23:05:59.953423 zmdc[17817].INF ['zmc -m 1' starting at 07/03/06 23:05:59, pid = 18352]
06.03.2007 23:05:59.967587 zmdc[17817].ERR ['zmc -m 1' exited abnormally, exit status 255]
06.03.2007 23:06:00.205456 zmdc[17817].INF ['zmc -m 2' starting at 07/03/06 23:06:00, pid = 18354]
06.03.2007 23:06:00.229294 zmdc[17817].ERR ['zmc -m 2' exited abnormally, exit status 255]
06.03.2007 23:05:59.574898 zmwatch[17877].ERR [Can't get shared memory id '7a6d2001', 1: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:59.575993 zmwatch[17877].INF [Restarting capture daemon for 207, shared memory not valid]
06.03.2007 23:05:59.975378 zmwatch[17877].INF ['zmc -m 1' starting at 07/03/06 23:05:59, pid = 18352]
06.03.2007 23:05:59.976347 zmwatch[17877].ERR [Can't get shared memory id '7a6d2002', 2: Aucun fichier ou répertoire de ce type]
06.03.2007 23:05:59.976541 zmwatch[17877].INF [Restarting capture daemon for 101, shared memory not valid]
06.03.2007 23:06:00.237789 zmwatch[17877].INF ['zmc -m 2' starting at 07/03/06 23:06:00, pid = 18354]
Mar 6 23:06:00 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 207, shared memory not valid]
Mar 6 23:06:00 Pascal5 zmdc[18352]: INF ['zmc -m 1' started at 07/03/06 23:05:59]
Mar 6 23:06:00 Pascal5 zmdc[17817]: INF ['zmc -m 1' starting at 07/03/06 23:05:59, pid = 18352]
Mar 6 23:06:00 Pascal5 zmc_m1[18352]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:06:00 Pascal5 zmwatch[17877]: INF ['zmc -m 1' starting at 07/03/06 23:05:59, pid = 18352]
Mar 6 23:06:00 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 101, shared memory not valid]
Mar 6 23:06:00 Pascal5 zmdc[17817]: INF ['zmc -m 2' starting at 07/03/06 23:06:00, pid = 18354]
Mar 6 23:06:00 Pascal5 zmdc[18354]: INF ['zmc -m 2' started at 07/03/06 23:06:00]
Mar 6 23:06:00 Pascal5 zmc_m2[18354]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:06:00 Pascal5 zmwatch[17877]: INF ['zmc -m 2' starting at 07/03/06 23:06:00, pid = 18354]
06.03.2007 23:06:10.243208 zmwatch[17877].ERR [Can't get shared memory id '7a6d2001', 1: Aucun fichier ou répertoire de ce type]
06.03.2007 23:06:10.244337 zmwatch[17877].INF [Restarting capture daemon for 207, shared memory not valid]
Mar 6 23:06:10 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 207, shared memory not valid]
06.03.2007 23:06:10.754148 zmdc[17817].INF ['zmc -m 1' starting at 07/03/06 23:06:10, pid = 18357]
06.03.2007 23:06:10.770527 zmdc[17817].ERR ['zmc -m 1' exited abnormally, exit status 255]
06.03.2007 23:06:10.978162 zmdc[17817].INF ['zmc -m 2' starting at 07/03/06 23:06:10, pid = 18359]
06.03.2007 23:06:11.006104 zmdc[17817].ERR ['zmc -m 2' exited abnormally, exit status 255]
06.03.2007 23:06:10.778665 zmwatch[17877].INF ['zmc -m 1' starting at 07/03/06 23:06:10, pid = 18357]
06.03.2007 23:06:10.779636 zmwatch[17877].ERR [Can't get shared memory id '7a6d2002', 2: Aucun fichier ou répertoire de ce type]
06.03.2007 23:06:10.779828 zmwatch[17877].INF [Restarting capture daemon for 101, shared memory not valid]
06.03.2007 23:06:11.027069 zmwatch[17877].INF ['zmc -m 2' starting at 07/03/06 23:06:10, pid = 18359]
Mar 6 23:06:10 Pascal5 zmdc[18357]: INF ['zmc -m 1' started at 07/03/06 23:06:10]
Mar 6 23:06:10 Pascal5 zmdc[17817]: INF ['zmc -m 1' starting at 07/03/06 23:06:10, pid = 18357]
Mar 6 23:06:10 Pascal5 zmc_m1[18357]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:06:10 Pascal5 zmwatch[17877]: INF ['zmc -m 1' starting at 07/03/06 23:06:10, pid = 18357]
Mar 6 23:06:10 Pascal5 zmwatch[17877]: INF [Restarting capture daemon for 101, shared memory not valid]
Mar 6 23:06:11 Pascal5 zmdc[18359]: INF ['zmc -m 2' started at 07/03/06 23:06:10]
Mar 6 23:06:11 Pascal5 zmdc[17817]: INF ['zmc -m 2' starting at 07/03/06 23:06:10, pid = 18359]
Mar 6 23:06:11 Pascal5 zmc_m2[18359]: INF [Debug Level = 0, Debug Log = <none>]
Mar 6 23:06:11 Pascal5 zmwatch[17877]: INF ['zmc -m 2' starting at 07/03/06 23:06:10, pid = 18359]
Posted: Tue Mar 06, 2007 11:47 pm
by cordel
Run both:
zmu -m 1 -q -v
zmu -m 2 -q -v
and post the results.
Posted: Wed Mar 07, 2007 12:57 pm
by breizhbug
cordel wrote:Run both:
zmu -m 1 -q -v
zmu -m 2 -q -v
Hello Cordel,
Both returns Abandon (core dumped)
What does that mean ?
Posted: Wed Mar 07, 2007 8:35 pm
by cordel
What settings did you use for your cameras?
Host?
Path?
Posted: Thu Mar 08, 2007 2:19 pm
by CoolRide
I have got exactly the same message. I solved this by changing the size of the monitor. I have set 352 x 240.
Kind regards
Vincent.
Posted: Wed Mar 21, 2007 8:13 pm
by japerlman
I am getting the same error on an Axis IP camera, which I believe is causing me to only see a black image with a "Status: Idle - 0.00 fps" when I try to view my camera through zoneminder.
below are the results of my zmu -m 5 -q -v
#zmu -m 5 -q -v
Monitor 5(New)
Type : Remote
Host : 10.9.1.187
Port : 80
Path : /axis-cgi/mjpg/video.cgi?resolution=320x240
Width : 320
Height : 240
Palette : 4
Colours : 3
Event Prefix : Event-
Label Format : %%s - %y/%m/%d %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 40
Warmup Count : 25
Pre Event Count : 10
Post Event Count : 10
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 30.00
Alarm Maximum FPS : 0.00
Reference Blend %ge : 7
Track Motion : 0
Function: 5 - Continuous Record with Motion Detection
Zones : 1
  Label : All
  Type: 1 - Active
  Shape : 4 points
    0: 0,0
    1: 319,0
    2: 319,239
    3: 0,239
  Alarm RGB : ff0000
  Check Method: 3 - Blobs
  Min Pixel Threshold : 25
  Max Pixel Threshold : 0
  Min Alarm Pixels : 2304
  Max Alarm Pixels : 57600
  Filter Box : 3,3
  Min Filter Pixels : 2304
  Max Filter Pixels : 57600
  Min Blob Pixels : 1536
  Max Blob Pixels : 0
  Min Blobs : 1
  Max Blobs : 0
Any help would be greatly appreciated!
Posted: Wed Mar 21, 2007 8:26 pm
by breizhbug
Try this,
/axis-cgi/jpg/image.cgi?resolution=320x240
instead of /axis-cgi/mjpg/video.cgi?resolution=320x240
It works with me
Posted: Wed Mar 21, 2007 8:45 pm
by japerlman
Well, that error stops showing up in the logs but I still am left with no image when I view the monitor.
Posted: Thu Mar 22, 2007 9:11 pm
by ammaross
I was dealing with this same type of problem just today actually. On an Axis 210, it was set to 640x480. Since it was over a slow DSL, I reduced the resolution to 320x240 and set the path to /axis-cgi/jpg/image.cgi?resolution=320x240 and set the capture size to 320x240. This setup didn't provide a picture for me for some reason. I tried the mjpg/video.cgi path with same settings to no avail. On the camera, I set the resolution back up to 640x480 and boing! Was capturing properly at the 320x240 settings I wanted. Not sure why it wouldn't work at the 320x240 setting though. Just try some variations and see if it starts working.
Oh, and on a side note, is your Axis camera set up to allow anonymous views, or did you set up the user/pass for it?
