Problem with Source Type: File
Posted: Fri Mar 09, 2007 11:45 am
System config details:
The jpg is a 640X480 capture (from a Linksys WVC54G).
When I try to access that I get the following in the logs:
Any suggestion as to how I can get Mon_ID 4 to display the jpg? It is extremely frustrating to have one file monitor jpg working and the other not. The second jpg is a good, valid image - I can see it in a normal web-broswer page.
TIA.
- Linux CentOS 4.4 (2.6.9-42.0.8.EL)
Apache 2.0.52 (CentOS) web-server
MySQL 4.1.20
PHP 4.3.9
ZoneMinder 1.22.3
http://www.zoneminder.com/downloads/zm- ... eset.patch is applied.
Shared memory modification is applied:
> kernel.shmall=134217728
> kernel.shmmax=134217728
- Mon_ID 2 is a Labtec USB web-cam feed. Working fine.
Mon_ID 3 is a file-structure located jpg file-read feed. Working fine. (BTW: I have noted that if I use a soft link to a file results in no display in ZM, the file pathname has to be an actual file and not a link. I do not know why this is: perhaps it is a documented feature?). However Mon_ID 3 is not the problem.
My problem is that Mon_ID 4 displays a blank screen (by blank I mean black). Mon_ID 4 is a second file-structure located jpg file-read feed. Different jpg file. But Not working.
Those details all look fine (at least to me!), and the file pathname is correct.# zmu -m 4 -q -v -Uuser -Ppwd
Monitor 4(WVC54GF1)
Type : File
Path : /home/www/MyTestWebSite/webcam/wcv54g_monitor.jpg
Width : 320
Height : 240
Palette : 1
Colours : 1
Event Prefix : Event-
Label Format : %%s - %d/%m/%y %H:%M:%S
Label Coord : 0,0
Image Buffer Count : 40
Warmup Count : 25
Pre Event Count : 10
Post Event Count : 10
Alarm Frame Count : 1
Section Length : 600
Maximum FPS : 1.00
Alarm Maximum FPS : 2.00
Reference Blend %ge : 7
Track Motion : 0
Function: 2 - Monitor Only
Zones : 1
Label : All
Type: 1 - Active
Shape : 4 points
0: 0,0
1: 319,0
2: 319,239
3: 0,239
Alarm RGB : ff0000
Check Method: 3 - Blobs
Min Pixel Threshold : 25
Max Pixel Threshold : 0
Min Alarm Pixels : 2304
Max Alarm Pixels : 57600
Filter Box : 3,3
Min Filter Pixels : 2304
Max Filter Pixels : 57600
Min Blob Pixels : 1536
Max Blob Pixels : 0
Min Blobs : 1
Max Blobs : 0
If I change to 320 x 240 (as indeed my zmu -m 4 -q above shows) I get the following errors in the logs:For 640 x 480 configuration:
# tail /var/log/messages
Mar 8 23:35:11 99dpr-004 zmu[26887]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:13 99dpr-004 zms[26893]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:15 99dpr-004 zmu[26895]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:18 99dpr-004 zms[26901]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:19 99dpr-004 zmu[26903]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:23 99dpr-004 zms[26910]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:24 99dpr-004 zmu[26912]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:28 99dpr-004 zmu[26921]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:29 99dpr-004 zms[26931]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
Mar 8 23:35:32 99dpr-004 zmu[26942]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
I've seen the shared memory notes in the FAQ and other forum threads. This I have addressed, as above, with the shared memory modification and the shared memory is as follows:# tail /var/log/messages
Mar 8 23:36:07 99dpr-004 zmdc[26644]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Mar 8 23:36:07 99dpr-004 zmdc[26644]: WAR [Can't find process with command of 'zma -m 4']
Mar 8 23:36:12 99dpr-004 zmdc[26644]: INF [Starting pending process, zmc -m 4]
Mar 8 23:36:12 99dpr-004 zmdc[26644]: INF ['zmc -m 4' starting at 07/03/08 23:36:12, pid = 26999]
Mar 8 23:36:12 99dpr-004 zmdc[26999]: INF ['zmc -m 4' started at 07/03/08 23:36:12]
Mar 8 23:36:12 99dpr-004 zmc_m4[26999]: INF [Debug Level = 0, Debug Log = <none>]
Mar 8 23:36:12 99dpr-004 zmc_m4[26999]: INF [Starting Capture]
Mar 8 23:36:12 99dpr-004 zmc_m4[26999]: ERR [Captured image does not match expected size, check width, height and colour depth]
Mar 8 23:36:12 99dpr-004 zmdc[26644]: ERR ['zmc -m 4' exited abnormally, exit status 255]
Mar 8 23:36:19 99dpr-004 zmu[27009]: ERR [Shared memory not initialised by capture daemon]
==> zmwatch.log <==
03/08/2007 23:37:37.529201 zmwatch[26696].INF [Restarting capture daemon for WVC54GF1, shared memory not valid]
03/08/2007 23:37:38.186470 zmwatch[26696].INF ['zmc -m 4' starting at 07/03/08 23:37:38, pid = 27188]
03/08/2007 23:37:48.199034 zmwatch[26696].INF [Restarting capture daemon for WVC54GF1, shared memory not valid]
03/08/2007 23:37:48.841988 zmwatch[26696].INF ['zmc -m 4' starting at 07/03/08 23:37:48, pid = 27208]
03/08/2007 23:37:58.848717 zmwatch[26696].INF [Restarting capture daemon for WVC54GF1, shared memory not valid]
03/08/2007 23:37:59.508231 zmwatch[26696].INF ['zmc -m 4' starting at 07/03/08 23:37:59, pid = 27234]
03/08/2007 23:38:09.514583 zmwatch[26696].INF [Restarting capture daemon for WVC54GF1, shared memory not valid]
03/08/2007 23:38:10.159987 zmwatch[26696].INF ['zmc -m 4' starting at 07/03/08 23:38:10, pid = 27257]
03/08/2007 23:38:20.167315 zmwatch[26696].INF [Restarting capture daemon for WVC54GF1, shared memory not valid]
03/08/2007 23:38:20.796681 zmwatch[26696].INF ['zmc -m 4' starting at 07/03/08 23:38:20, pid = 27283]
I have debug set to level 4 but cannot get the /var/log/zm/zm_debug.log+ files to appear. I restarted zm (servicec zm restart) after setting this, but still no detailed log (as you can see above, Debug Level is 0 and I cannot move it off that). So something is not right there either.# ipcs -m
------ Shared Memory Segments --------
key shmid owner perms bytes nattch status
0x00000000 22249472 gdm 600 393216 2 dest
0x7a6d2004 27426817 apache 700 3073188 0
0x7a6d2002 26476546 apache 700 9217188 2
0x7a6d2003 26509315 apache 700 9217188 1
TIA.
