Configuration backup
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
breizhbug
Post by breizhbug »
Is it possible to backup configuration ou zm console to a config file ou sql script in order to load backup conf file after software release for example or to duplicate server.
Or is there a file to copy/paste ?
Pascal
zoneminder
Site Admin
Post by zoneminder »
If you just mean the system config then you could mysqldump the Config database table. If you want to include monitors then you will additionally need to include the Monitors and Zones table but this is a little less convenient and you might as well do the whole database. I think there are backup/restore scripts in the user contribs forum though.
Phil
