Page 1 of 2
Problems with pico 2000 card
Posted: Tue Mar 13, 2007 2:27 pm
by danielareas
I'm having two problems with pico 2000 card: 1) one of the four channels is in Black&White, I've already swithched the cables to be ceirtain the problem wasn´t in the câmera. All other three channels are in color. I even traded the card for a new one thinking it had a defect, and nothing changed. 2) The capture of the images is too slow, after watching some streams of images, the site literally stops sayng it's loading, and nothing else happens. Can anybody help me? I´m running ZM on UBUNTU.
Posted: Wed Mar 14, 2007 3:49 am
by Taz
1)
edit your /etc/modprobe.conf
and at the bottom of the file put this line like your system (1 or 2 cards)
For one card:
options bttv card=77 tuner=-1 radio=0 triton1=0 vsfx=0 autoload=0
For two cards:
options bttv card=77,77 tuner=-1,-1 radio=0,0 triton1=0 vsfx=0 autoload=0
I'm 100% sure that your B&W problem on channel 2 will desapear
2) About the slow movements, this damn card doesn't show more than 2.5 fps. Also set ZM to show as jpg instead mpeg and jpg quality to 50% it will solve all your problems.
Taz
ps: i'll send you the Bill later
Posted: Wed Mar 14, 2007 12:30 pm
by danielareas
, THanks a lot!!
Best Video Capture Boards
Posted: Mon Mar 19, 2007 2:29 pm
by danielareas
Hello Taz,
Do you happen to know which video capture boards have the best cost/benefit working with Zoneminder?
thanks!!
Daniel Brito
'Montage' does´t work with PICO 2000
Posted: Mon Apr 09, 2007 2:18 pm
by danielareas
Can any body help me?
I did these configurations to get my PICO 2000 board working properly:
1) edit /etc/modprobe.conf
For one card:
For two cards:
2) About the slow movements, this damn card doesn't show more than 2.5 fps. Also set ZM to show as jpg instead mpeg and jpg quality to 50% .
The problem is that, when I go to 'Montage' Mode, I can't get the application to show me all four streams at the same time. Am I doing something wrong? Am I wsing wrong drivers? These streams are too slow!!! I'm woried because this is happening with only four channels, I'm affraid of whats going to happen with 16 channels.
Posted: Tue Apr 10, 2007 5:23 am
by Sika
Are you using FireFox web browser to view ZM? Can you view each channel independently? If so you'll probably have to make some adjustments to your Firefox browser. Google will help you on this one.
Sika
Montage too slow.
Posted: Tue Apr 10, 2007 12:33 pm
by danielareas
So it turns de montage screen into an useless option in the zm system?
Because I see a lot of users interested in monitoring all cameras at the same time, there should be other way too improove the speed of these image streams?
Daniel Areas
Posted: Tue Apr 10, 2007 12:55 pm
by jameswilson
no it is not a useless option, its a problem with firefox where some settings can be changed to fix it in firefox. ie with cambazola doesnt have the problem.
re the framerate if your using a single chip card then this is what happens. If you want more framerate buy a better card.
James
Config Firefox
Posted: Tue Apr 10, 2007 2:12 pm
by danielareas
Mr. James Wilson,
Do you know what are the configurations I have to execute on Firefox?
thank you,
Daniel Brito
Posted: Tue Apr 10, 2007 4:57 pm
by cordel
STFW or check the wiki FAQ.
Funny guy
Posted: Tue Apr 10, 2007 11:43 pm
by danielareas
Cordel,
All I have to say is: "Real cute!!!"
Daniel Arêas
Posted: Tue Apr 10, 2007 11:49 pm
by cordel
Okay, here is the link
http://www.zoneminder.com/wiki/index.ph ... FireFox.3F
or search for "firefox browser cache"
Does that help
Sorry, had 30 people on my back at the time, so was an attempt to be short and sweet, but may not so sweet looking back.
Posted: Wed Apr 11, 2007 12:50 am
by jameswilson
corey id have said wiki too short, sweet and to the point
Channel 3
Posted: Thu May 24, 2007 12:32 pm
by danielareas
I'm still having a problem with the pico 2000 card. Channel 3 is in color now, but it doesn´t detect any events. Did I forget to configure anything?
Posted: Fri Jun 01, 2007 3:11 pm
by alex
For one card:
I have this card and am having great difficult in getting it to work! Lots of searching on this forum and on the wiki indicates I need to edit /etc/modprobe.conf
Why do I not have this file?!
I installed on Ubuntu using
http://www.zoneminder.com/wiki/index.php/Ubuntu_7.04
Any ideas?
Thanks.
