Control FPS
gardo
Control FPS
Post by gardo »
Is there a way to set the recording FPS? I would like to record at 5 FPS. I have the Maximum FPS set to 5.00. However, when a zone alarm is triggered, it keeps jumping up to 20-25 FPS.
Ryan
gardo
Re: Control FPS
Post by gardo »
I see under options, there is a "Should we override Maximum FPS?" or something like that. That is not checked. I am testing by "Force Alarm", does that not follow those rules?
Ryan
zoneminder
Site Admin
Re: Control FPS
Post by zoneminder »
Hi Ryan,
Do you mean ZM_NO_MAX_FPS_ON_ALARM? If so then this should prevent the FPS increasing when an alarm occurs? I don't think force alarm makes any difference to that.
I will try and see if there is a problem somewhere.
Cheers,
Phil,
fernando
Re: Control FPS
Post by fernando »
i think he talk about ftp recording.. not streaming
gardo
Re: Control FPS
Post by gardo »
I'm talking about recording to the hard drive. If I click "force alarm", then it jumped to capturing at 25fps.
Ryan
zoneminder
Site Admin
Re: Control FPS
Hi Ryan,
As I said above, this is controlled by the ZM_NO_MAX_FPS_ON_ALARM option. You mentioned it was unchecked but I'm wondering if there is a problem perhaps with the value held in the database.
Are you able to check your DB and see what the information held for this option is in the Config table? If you need any assistance please let me know.
Cheers,
Phil,
