Page 1 of 2
No capture on zm 1.22.3 package etch
Posted: Mon Mar 19, 2007 1:15 pm
by nadir
Hi all!
I have installed zm from depot sid in my etch .make the ln-s.with succes
my webcam logitech 4000 pro is automaticly detected kernel 2.6.18.k7 and run with xawtv
but i have nothing (images) in zm .
so are there some setting to make after installtion like PATH zms or nph-zms or something else
thank you
More details, please
Posted: Wed Mar 21, 2007 12:39 am
by PeterHoward
Right now I'm not sure if this is a packaging problem, or a zoneminder problem. Could you please go through at length the steps you've taken. Starting from what you've already said:
- apt-get install zoneminder
linked the apache config fragment
got to http://{hostname}/zm
So far correct? Could you now talk through how you defined your camera (video source, resolution, etc)? And do you see a broken link on the viewing page, or just a blank box?
PJH
re :
Posted: Wed Mar 21, 2007 4:09 pm
by nadir
Hi!
myhost/zm /home/nadir/zm.png
[/img]
re :
Posted: Wed Mar 21, 2007 4:21 pm
by nadir
Hi!
with myhost/zm it work
i add a new monitor CAM1
webcam /dev/video0
local,monitor ;resolution 320*240;i have try all the device channel and capture palette and other resolution aftre zmu -d /dev/video0. The link CAM1 is blank box.
i have change the cgi-bin in zms without result
the LOGs
debian:/home/nadir# tail -f /tmp/*.log
==> /tmp/zmaudit.log <==
03/21/07 16:48:53.105251 zmaudit[2957].DBG [Found filesystem monitor '1']
03/21/07 16:48:53.112500 zmaudit[2957].DBG [Got 0 events]
03/21/07 17:03:53.121080 zmaudit[2957].DBG [Found database monitor '1']
03/21/07 17:03:53.121421 zmaudit[2957].DBG [Got 0 events]
03/21/07 17:03:53.121574 zmaudit[2957].DBG [Found filesystem monitor '1']
03/21/07 17:03:53.121683 zmaudit[2957].DBG [Got 0 events]
03/21/07 17:18:53.128323 zmaudit[2957].DBG [Found database monitor '1']
03/21/07 17:18:53.128755 zmaudit[2957].DBG [Got 0 events]
03/21/07 17:18:53.128907 zmaudit[2957].DBG [Found filesystem monitor '1']
03/21/07 17:18:53.129014 zmaudit[2957].DBG [Got 0 events]
==> /tmp/zmdc.log <==
03/21/07 17:20:12.836860 zmdc[2930].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:12, pid = 4023]
03/21/07 17:20:12.846729 zmdc[2930].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/21/07 17:20:22.989400 zmdc[2930].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:22, pid = 4025]
03/21/07 17:20:22.994967 zmdc[2930].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/21/07 17:20:33.130073 zmdc[2930].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:33, pid = 4028]
03/21/07 17:20:33.142556 zmdc[2930].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/21/07 17:20:43.282652 zmdc[2930].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:43, pid = 4030]
03/21/07 17:20:43.294117 zmdc[2930].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/21/07 17:20:53.439263 zmdc[2930].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:53, pid = 4032]
03/21/07 17:20:53.450164 zmdc[2930].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
==> /tmp/zmfilter.log <==
03/21/07 17:12:58.291789 zmfilter[2955].DBG [Reloading filters]
03/21/07 17:12:58.292154 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:13:58.299236 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:14:58.309582 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:15:58.314108 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:16:58.317600 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:17:58.320963 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:18:58.324395 zmfilter[2955].DBG [Reloading filters]
03/21/07 17:18:58.324754 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:19:58.327853 zmfilter[2955].DBG [Sleeping for 60 seconds]
==> /tmp/zmpkg.log <==
03/21/07 16:48:48.670673 zmpkg[2920].INF [Command: start]
==> /tmp/zmupdate.log <==
03/21/07 16:48:54.264621 zmupdate[2963].INF [Checking for updates]
03/21/07 16:48:55.186685 zmupdate[2963].INF [Got version: '1.22.3']
==> /tmp/zmwatch.log <==
03/21/07 17:20:12.705177 zmwatch[2961].INF [Restarting capture daemon for CAM1, shared memory not valid]
03/21/07 17:20:12.850311 zmwatch[2961].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:12, pid = 4023]
03/21/07 17:20:22.854286 zmwatch[2961].INF [Restarting capture daemon for CAM1, shared memory not valid]
03/21/07 17:20:22.998546 zmwatch[2961].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:22, pid = 4025]
03/21/07 17:20:33.002329 zmwatch[2961].INF [Restarting capture daemon for CAM1, shared memory not valid]
03/21/07 17:20:33.146187 zmwatch[2961].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:33, pid = 4028]
03/21/07 17:20:43.150909 zmwatch[2961].INF [Restarting capture daemon for CAM1, shared memory not valid]
03/21/07 17:20:43.297920 zmwatch[2961].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:43, pid = 4030]
03/21/07 17:20:53.307485 zmwatch[2961].INF [Restarting capture daemon for CAM1, shared memory not valid]
03/21/07 17:20:53.453734 zmwatch[2961].INF ['zmc -d /dev/video0' starting at 07/03/21 17:20:53, pid = 4032]
03/21/07 17:20:58.335326 zmfilter[2955].DBG [Sleeping for 60 seconds]
03/21/07 17:21:03.603748 zmdc[2930].INF ['zmc -d /dev/video0' starting at 07/03/21 17:21:03, pid = 4035]
03/21/07 17:21:03.612885 zmdc[2930].ERR ['zmc -d /dev/video0' exited abnormally, exit status 255]
03/21/07 17:21:03.464078 zmwatch[2961].INF [Restarting capture daemon for CAM1, shared memory not valid]
03/21/07 17:21:03.616899 zmwatch[2961].INF ['zmc -d /dev/video0' starting at 07/03/21 17:21:03, pid = 4035]
[/list]
re :
Posted: Wed Mar 21, 2007 4:31 pm
by nadir
Re: re :
Posted: Wed Mar 21, 2007 10:51 pm
by PeterHoward
The key part of the output is this bit
Note the "shared memory not valid"
If you search on "shared memory" in the forums you'll find a
wealth of posts about problems with shared memory, including two threads by me having troubles with them
My initial guess is that, somewhere along the way, a block of shared memory got left around. But I could be wrong, and there's lots of posts about it.
At this stage I don't think it's specific to the debian package, though I'm ready to be proven wrong. Let me know how your search goes.
PJH
re
Posted: Wed Mar 21, 2007 11:10 pm
by nadir
so the problem is in the key memory?
i have change them after
#ipcs -m and no result
Posted: Wed Mar 21, 2007 11:14 pm
by PeterHoward
That could be one of the problems. Another could be related to permissions on /dev/video0 - what are they?
re
Posted: Wed Mar 21, 2007 11:28 pm
by nadir
my /dev/video0 run under xawtv in single user or root
This isn't xawtv
Posted: Wed Mar 21, 2007 11:36 pm
by PeterHoward
Yes, but I've found zm to be much fussier about permissions. Specifically it seems to want o+rw.
re
Posted: Wed Mar 21, 2007 11:46 pm
by nadir
in zm
dev/video0 is not in red
change permission
Posted: Wed Mar 21, 2007 11:58 pm
by nadir
How to change permission for dev/video0 for zm ?
i must change group in www-data and +rw ?
Posted: Thu Mar 22, 2007 12:04 am
by PeterHoward
The simplest form is
either with sudo or as root.
However, I think you're right; it should be red (not orange) in the zoneminder screen if perms was the problem. So it doesn't hurt to try, but don't be too hopeful. Also, make sure you stop and restart zm around the change.
But basically I'm hoping someone like Cordel is going to jump in to this thread sometime soon as I'm running out of obvious suggestions.
re
Posted: Thu Mar 22, 2007 12:11 am
by nadir
ok, thank you very much ,i try this tomorow and i tell you the result.
sorry for my english.
Posted: Thu Mar 22, 2007 12:34 am
by cordel
I was just getting up to speed on the package installation for Deb in the wiki so hopefully it's still correct. First I need more active log notes (See
here for direction on this) or root ssh access to the machine (which info should be PMed to me for obvious reasons) so that I can look at the logs and make necessary changes. If you sources are showing up green then this is a good thing and usualy means that zms is able to capture an image from the device.
