Page 1 of 1
EXPORT FAILED during export
Posted: Wed Mar 21, 2007 5:35 pm
by captain_morgan
Whevever I try to export to any file type, I simply get EXPOIRT FAILED at the bottom. If I check off any of the other buttons, such as event details, I get Can't open event detail export file 'zmEventDetail.html'
The video is there, but it just won't export. Where should I start to look to resolve this problem.
Posted: Wed Mar 21, 2007 9:13 pm
by cordel
The logs would be a good place to start.
Posted: Fri Mar 23, 2007 4:16 pm
by japerlman
I'm also getting this error, but only when I have the 'export video' checkbox on.
Below is my /var/log/messages I'm guessing it has something to do with the 'Error while writing video frame'
Mar 23 12:13:28 gentoo-dvr zmdc[14016]: INF ['zma -m 2' starting at 07/03/23 12:13:28, pid = 22972]
Mar 23 12:13:28 gentoo-dvr zmdc[22972]: INF ['zma -m 2' started at 07/03/23 12:13:28]
Mar 23 12:13:28 gentoo-dvr zma_m2[22972]: INF [Debug Level = 0, Debug Log = <none>]
Mar 23 12:13:28 gentoo-dvr zmdc[14016]: INF ['zma -m 2' exited normally]
Mar 23 12:14:02 gentoo-dvr zms[23047]: FAT [Error while writing video frame]
Mar 23 12:14:02 gentoo-dvr zms[23047]: ERR [Got signal (Aborted), crashing]
Mar 23 12:14:02 gentoo-dvr zms[23047]: ERR [Signal address is (nil), from 0xb7f16410 ]
Mar 23 12:14:02 gentoo-dvr zms[23047]: ERR [Backtrace: [0xb7f16410]]
Mar 23 12:14:02 gentoo-dvr zms[23047]: ERR [Backtrace: /lib/libc.so.6(abort+0x109) [0xb7674c69]]
Mar 23 12:14:02 gentoo-dvr zms[23047]: ERR [Backtrace: /usr/share/webapps/zoneminder/1.22.3/hostroot/cgi-bin/nph-zms [0x806f0c7]]
Mar 23 12:14:02 gentoo-dvr zms[23049]: FAT [Error while writing video frame]
Mar 23 12:14:02 gentoo-dvr zms[23049]: ERR [Got signal (Aborted), crashing]
Mar 23 12:14:02 gentoo-dvr zms[23049]: ERR [Signal address is (nil), from 0xb7f09410 ]
Mar 23 12:14:02 gentoo-dvr zms[23049]: ERR [Backtrace: [0xb7f09410]]
Mar 23 12:14:02 gentoo-dvr zms[23049]: ERR [Backtrace: /lib/libc.so.6(abort+0x109) [0xb7667c69]]
Mar 23 12:14:02 gentoo-dvr zms[23049]: ERR [Backtrace: /usr/share/webapps/zoneminder/1.22.3/hostroot/cgi-bin/nph-zms [0x806f0c7]]
Mar 23 12:14:23 gentoo-dvr zmc_m3[20030]: INF [New: 9000 - Capturing at 3.36 fps]
Mar 23 12:14:49 gentoo-dvr zmc_m1[16919]: INF [New: 17000 - Capturing at 3.34 fps]
Any help would be greatly appreciated.
Posted: Fri Mar 23, 2007 5:40 pm
by cordel
Wrong log, zms has nothing to do exporting so thats something else.
Check your apache error log.
Posted: Fri Mar 23, 2007 6:02 pm
by japerlman
It seems if I choose tar as my export type it works, but I just get an empty archive.
I'm wondering if the problem is there is no video files to export. All i see are jpeg but i was my impression that it just joined the jpegs into a mpeg then exported that mpeg.
Is that the correct behavior or do I have to take a few steps back and get video files being saved first?
zip error: Nothing to do! (temp/zmExport.zip)
[Fri Mar 23 13:59:30 2007] [error] [client 10.9.1.196] Command 'cat temp/zmFileList.txt | zip -q temp/zmExport.zip -@' returned with status 12, referer: http://10.9.1.90/index.php?view=export&eid=204
Posted: Fri Mar 23, 2007 6:10 pm
by robi
You need to create the video first. If there's no video file, naturally it will not be included in the archive. Tick all the options and see what you get.
Posted: Fri Mar 23, 2007 6:41 pm
by japerlman
How do I get it to record a video file then as it is not apparant to me...
I went under options -> images and switched it from jpeg to mpeg and when I monitor the camera it is clearly using mpeg with compression as opposed to mjpeg...
What other settings do I have to modify to record video?
Much thanks,
Jason.
Posted: Fri Mar 23, 2007 6:59 pm
by robi
In the event window, click on video first, to generate an mpeg.
Posted: Fri Mar 23, 2007 7:07 pm
by japerlman
Thanks...
I'm an artard.
I was assuming it would generate that video file on demand when you try to export 'video'.
