Page 1 of 1
LDAP User Authentication
Posted: Tue Apr 03, 2007 10:50 pm
by Solar
I searched around a bit on the forums, but couldn't come across anyone that played with using ZoneMinder to authenticate agains a LDAP server. I know it is possible to instead setup Apache to only allow authenticated users access to a specific resource (and thereby implimenting LDAP functionality from that side), but I decided to encorporate the LDAP support directly into ZoneMinder.
I wrote a set of php functions that use PHP_LDAP, and only changed half-a-line in the original ZM source to make this work. It firstly checks if the user exists in the local ZM db, and then goes on to find the users CN (by just using the username in the ZM db). If this is successful, it tries to bind to LDAP using the password supplied. It seems to be working great.
We are using ZoneMinder at the University of Stellenbosch in South Africa at the Electronical Engineering department. The authentication is now done against the university Windows 2003 ldap machines.
I also integrated the access control logs of the doors (stored centrally in PostgreSQL) with the events in ZM, and users of ZM can click on the hyperlinked student numbers to get access to the student's details (photo, name, academic details) from another university server with a Postgres Server.
If someone is interested in the LDAP extensions I can post it for download.
Regards,
Christiaan[/img]
neat!
Posted: Tue Sep 18, 2007 9:04 am
by Jancis
this could be pretty usefull ;) Altrought i was planning to use external autorization for ZM and then use Apache`s LDAP module to authorize against LDAP server at our University :)
Anyway - good job!
LDAP Module
Posted: Fri Nov 16, 2007 2:27 am
by jaredfarheap
Is this working currently, and if so, could you post it some where so I can use it / modify it to work with our zoneminder implementation?
Re: LDAP User Authentication
Posted: Thu Sep 24, 2015 10:22 pm
by gustavoms
Could you please post the code ?
Posted: Tue Feb 04, 2025 8:32 pm
by sabalar
Hi @solar, do mind sharing steps on how you were able to get ldap authentication to work through apache and zm db? Im cureently using zoneminder 1.36 and mariaDb, and have had no luck with my current setup.
