Page 1 of 1
Axis 2130 PTZ cam & Dlink 3220
Posted: Thu Apr 12, 2007 4:45 am
by AL
Can anybody give me the 'Remote Host Path' code for Axis 2130 PTZ cam and Dlink 3220/G inside the Source Tab? I need it immediately~!
Posted: Thu Apr 12, 2007 7:05 am
by Flasheart
Axis have a url-builder to the specification you need as part of the camera settings.
Use that, you don't give us enough information re size, colour depth etc to do it for you.
Posted: Thu Apr 12, 2007 7:19 am
by W.
Posted: Thu Apr 12, 2007 8:57 am
by AhNorm
size is 320x240 and the color is 24 bit. Please help me~!
Posted: Thu Apr 12, 2007 9:29 am
by jameswilson
as above there is a utility inside the cams setup page that will generate this for you
Posted: Thu Apr 12, 2007 10:35 am
by jlnavio
I have a 231D+ Axis Cam and it works fine with these two paths:
/axis-cgi/jpg/image.cgi?resolution=CIF
/axis-cgi/mjpg/video.cgi?resolution=CIF
I hope it was useful for you
