pico 2000 resolution
ilababy
Post by ilababy »
I have pico 2000 card with 4 camera.
It's work fine but only with 320x240 resolution.
Can i change (increase) the resolution?
Thanks.
Sorry for my english
cordel
Post by cordel »
That is the maximum you can go without interlacing.
You can set 640x480 but unless you have a expensive progressive scan camera, I would not suggest it.
robi
Post by robi »
cordel wrote:That is the maximum you can go without interlacing.
Progressive camera is not enough, as the bt8x8 chips can capture only interlaced above 384x288. A HD-compatible card would perhaps do the progressive thing.
v1.25.0 + Ubuntu Linux 12.04 Server
