Bug in capture daemon ...
mgg
Post by mgg »
Hi all
I have been testing some jpeg mode cams ( not mjpeg ). As I see capture daemon is pulling stills from the cam.
I still haven't found an ip cam that has user limit and works correctly with zm .
I tested live install and rpm on SuSE 10.2
I opened "iptraf" while zm doing captures and here is what is showed.
It opens one or two simultaneous sessions using one or the other, and that is fine if one wants max frames.
The problem is that it starts opening more and more sessions without closing previously opened. So naturally it tops out user count and stops pulling frames.
On axis models it stops when it reaches 20 + sessions.
As I said I still haven't found an ip can that has user limit and does jpeg stills and works correctly.
I could connect all cams trough proxy that makes only one or less than limit connections but I dont consider this as a elegant solution.
Did anyone try to play with zmc and dig in to code ?
Can this be set as a switch while compiling binaries ?
