Page 1 of 1
Install fail at make
Posted: Mon Apr 30, 2007 7:24 am
by ignition
Zoneminder 1.22.3
Slackware 10.2
Kernel 2.6.21
latest ffmpeg svn
./configure works ok
at make I have the error:
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include -I/usr/include -g -O2 -MT zm_event.o -MD -M
-o zm_event.o zm_event.cpp; \
then mv -f ".deps/zm_event.Tpo" ".deps/zm_event.Po"; else rm -f ".deps/zm_event.Tpo"; exit 1; fi
In file included from zm_mpeg.h:27,
from zm_event.cpp:29:
/usr/local/include/ffmpeg/avformat.h: In function `void
av_init_packet(AVPacket*)':
/usr/local/include/ffmpeg/avformat.h:66: error: `INT64_C' undeclared (first use
this function)
/usr/local/include/ffmpeg/avformat.h:66: error: (Each undeclared identifier is
reported only once for each function it appears in.)
make[2]: *** [zm_event.o] Error 1
make[2]: Leaving directory `/kituri/zoneminder/ZoneMinder-1.22.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/kituri/zoneminder/ZoneMinder-1.22.3'
make: *** [all] Error 2
root@core:/kituri/zoneminder/ZoneMinder-1.22.3#
Posted: Mon Apr 30, 2007 8:17 am
by cordel
Posted: Mon Apr 30, 2007 9:07 am
by ignition
Problem solved.
Thank you.
