Toshiba IK-WB15A , __Live.jpg issue
Posted: Tue May 01, 2007 11:32 pm
hi again.
briefly:
Just got a IK-WB15A in. Trying to add it to my zoneminder install which has a IKWB11A. Both cameras have a __live.jpg shot which works well with zoneminder.
Example: If i go to
http://192.168.100.98/admin/__live.jpg? ... =&aWt3Yg==
(the last part is base 64 encoding, thats the stock user/pass for these cams (root,ikwb)
I get a live shot from the camera in my browser
strangely this has always worked with the toshiba cams of this style. I put this info in Zoneminder, and I get no image. Below is log output pertinent to this event, as well as my zm.conf.
I noticed a shared memory reference issue in zmwatch.log, although i have set the memory as instructed in the FAQ. (Basically added the lines to my sysctl.conf) I think this is the issue, as it specifically complains about the Toshiba IKWB15A. I will continue perusing the forums for a solution until someone smarter than me sees this.
ZM Version: 1.22.3
Ubuntu 6.10 Edgy Eft installed via Wiki (fresh install)
2 cameras ATM: IK-WB11A (low bandwidth cam) and IK-WB15A (labeled as such)
zmdc.log
zwatch.log
[/code]
briefly:
Example: If i go to
ZM Version: 1.22.3
zmdc.log
05/01/07 19:17:54.203046 zmdc[7398].ERR ['zmc -m 2' exited abnormally, exit status 255]
05/01/07 19:18:15.971250 zmdc[7398].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/01/07 19:18:15.971619 zmdc[7398].INF [Starting pending process, zmc -m 1]
05/01/07 19:18:15.976780 zmdc[7398].INF ['zmc -m 1' starting at 07/05/01 19:18:15, pid = 7714]
05/01/07 19:18:28.007071 zmdc[7398].INF [Starting pending process, zmc -m 3]
05/01/07 19:18:28.011237 zmdc[7398].INF ['zmc -m 3' starting at 07/05/01 19:18:28, pid = 7720]
05/01/07 19:18:28.023004 zmdc[7398].ERR ['zmc -m 3' exited abnormally, exit status 255]
05/01/07 19:19:21.207178 zmdc[7398].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/01/07 19:19:21.207550 zmdc[7398].INF [Starting pending process, zmc -m 1]
05/01/07 19:19:21.212770 zmdc[7398].INF ['zmc -m 1' starting at 07/05/01 19:19:21, pid = 7765]
05/01/07 19:19:58.174496 zmdc[7398].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/01/07 19:20:03.075692 zmdc[7398].INF [Starting pending process, zmc -m 1]
05/01/07 19:20:03.079831 zmdc[7398].INF ['zmc -m 1' starting at 07/05/01 19:20:03, pid = 7787]
05/01/07 19:21:20.416472 zmdc[7398].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/01/07 19:21:24.703121 zmdc[7398].INF ['zmc -m 1' starting at 07/05/01 19:21:24, pid = 7822]
05/01/07 19:23:14.033396 zmdc[7398].INF [Starting pending process, zmc -m 2]
05/01/07 19:23:14.037568 zmdc[7398].INF ['zmc -m 2' starting at 07/05/01 19:23:14, pid = 7864]
05/01/07 19:23:14.132855 zmdc[7398].ERR ['zmc -m 2' exited abnormally, exit status 255]
05/01/07 19:23:48.000158 zmdc[7398].INF [Starting pending process, zmc -m 3]
05/01/07 19:23:48.005719 zmdc[7398].INF ['zmc -m 3' starting at 07/05/01 19:23:48, pid = 7880]
05/01/07 19:23:48.014641 zmdc[7398].ERR ['zmc -m 3' exited abnormally, exit status 255]
05/01/07 19:26:19.296345 zmdc[7398].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/01/07 19:26:19.296722 zmdc[7398].INF [Starting pending process, zmc -m 1]
05/01/07 19:26:19.301893 zmdc[7398].INF ['zmc -m 1' starting at 07/05/01 19:26:19, pid = 7953]
05/01/07 19:26:33.611290 zmdc[7398].ERR ['zmc -m 1' exited abnormally, exit status 255]
05/01/07 19:26:38.025521 zmdc[7398].INF [Starting pending process, zmc -m 1]
05/01/07 18:21:24.681514 zmwatch[4708].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 18:21:24.840613 zmwatch[4708].INF ['zmc -m 2' starting at 07/05/01 18:21:24, pid = 5793]
05/01/07 18:21:34.844832 zmwatch[4708].ERR [Can't get shared memory id '7a6d2002', 2: No such file or directory]
05/01/07 18:21:34.845207 zmwatch[4708].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 18:21:35.035637 zmwatch[4708].INF ['zmc -m 2' starting at 07/05/01 18:21:35, pid = 5834]
05/01/07 18:21:45.042493 zmwatch[4708].ERR [Can't get shared memory id '7a6d2002', 2: No such file or directory]
05/01/07 18:21:45.042813 zmwatch[4708].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 18:21:45.213939 zmwatch[4708].INF ['zmc -m 2' starting at 07/05/01 18:21:45, pid = 5855]
05/01/07 18:22:05.224312 zmwatch[4708].ERR [Can't get shared memory id '7a6d2002', 2: No such file or directory]
05/01/07 18:22:05.224679 zmwatch[4708].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 18:22:05.390993 zmwatch[4708].INF ['zmc -m 2' starting at 07/05/01 18:22:05, pid = 5872]
05/01/07 18:22:15.395230 zmwatch[4708].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 18:22:15.552539 zmwatch[4708].INF ['zmc -m 2' starting at 07/05/01 18:22:15, pid = 5885]
05/01/07 18:42:56.251411 zmwatch[4708].ERR [Can't get shared memory id '7a6d2002', 2: No such file or directory]
05/01/07 18:42:56.251636 zmwatch[4708].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 18:42:56.382903 zmwatch[4708].INF ['zmc -m 2' starting at 07/05/01 18:42:56, pid = 6460]
05/01/07 19:13:13.959475 zmwatch[7430].INF [Watchdog starting]
05/01/07 19:13:13.959863 zmwatch[7430].INF [Watchdog pausing for 30 seconds]
05/01/07 19:13:43.966830 zmwatch[7430].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 19:13:44.148856 zmwatch[7430].INF ['zmc -m 2' starting at 07/05/01 19:13:44, pid = 7466]
05/01/07 19:13:54.153910 zmwatch[7430].ERR [Can't get shared memory id '7a6d2002', 2: No such file or directory]
05/01/07 19:13:54.154336 zmwatch[7430].INF [Restarting capture daemon for Toshiba-IKWB15A, shared memory not valid]
05/01/07 19:13:54.304687 zmwatch[7430].INF ['zmc -m 2' starting at 07/05/01 19:13:54, pid = 7491]
05/01/07 19:21:24.550361 zmwatch[7430].INF [Restarting capture daemon for lowBandwidth, time since last capture 6 seconds ($
05/01/07 19:21:24.705905 zmwatch[7430].INF ['zmc -m 1' starting at 07/05/01 19:21:24, pid = 7822]
05/01/07 19:27:44.938483 zmwatch[7430].INF [Restarting capture daemon for lowBandwidth, time since last capture 8 seconds ($
05/01/07 19:27:45.110239 zmwatch[7430].INF ['zmc -m 1' starting at 07/05/01 19:27:45, pid = 8002]
[/code]
