Page 1 of 1
Logitech Quickcam Ultra Vision
Posted: Wed May 02, 2007 5:07 pm
by BadFish
So I have FC5 running ZM 1.22.3 and it works just fine with a Composite Video cam. everything seems to work just fine... :D
However I am also trying to install a USB Logitech Quickcam Ultra Vision but I am having some issues with this.
I can't seem to find the source for the video on the webcam. I thought it would be something like /dev/video1 or something like that but when I check
/dev I only find video0
urandom
crw------- 1 root root 253, 0 May 2 08:28 usbdev1.1_ep00
crw------- 1 root root 253, 1 May 2 08:28 usbdev1.1_ep81
crw------- 1 root root 253, 4 May 2 08:28 usbdev1.2_ep00
crw------- 1 root root 253, 5 May 2 08:28 usbdev1.2_ep87
crw------- 1 root root 253, 2 May 2 08:28 usbdev2.1_ep00
crw------- 1 root root 253, 3 May 2 08:28 usbdev2.1_ep81
lrwxrwxrwx 1 root root 4 May 2 08:28 vbi -> vbi0
crw----rw- 1 root root 81, 224 May 2 08:28 vbi0
crw------- 1 vcsa tty 7, 0 May 2 08:28 vcs
crw------- 1 vcsa tty 7, 1 May 2 08:29 vcs1
crw------- 1 vcsa tty 7, 2 May 2 08:29 vcs2
crw------- 1 vcsa tty 7, 3 May 2 08:29 vcs3
crw------- 1 vcsa tty 7, 4 May 2 08:29 vcs4
crw------- 1 vcsa tty 7, 5 May 2 08:29 vcs5
crw------- 1 vcsa tty 7, 6 May 2 08:29 vcs6
crw------- 1 vcsa tty 7, 128 May 2 08:28 vcsa
crw------- 1 vcsa tty 7, 129 May 2 08:29 vcsa1
crw------- 1 vcsa tty 7, 130 May 2 08:29 vcsa2
crw------- 1 vcsa tty 7, 131 May 2 08:29 vcsa3
crw------- 1 vcsa tty 7, 132 May 2 08:29 vcsa4
crw------- 1 vcsa tty 7, 133 May 2 08:29 vcsa5
crw------- 1 vcsa tty 7, 134 May 2 08:29 vcsa6
lrwxrwxrwx 1 root root 6 May 2 08:28 video -> video0
crw----rw- 1 root root 81, 0 May 2 08:28 video0
drwx------ 2 root root 80 May 2 08:28 VolGroup00
lrwxrwxrwx 1 root root 4 May 2 08:28 X0R -> null
crw-rw-rw- 1 root root 1, 5 May 2 08:28 zero
And this is the dmesg
Linux version 2.6.20-1.2312.fc5 (brewbuilder@hs20-bc1-7.build.redhat.com) (gcc version 4.1.1 20070105 (Red Hat 4.1.1-51)) #1 T
ue Apr 10 15:09:44 EDT 2007
BIOS-provided physical RAM map:
sanitize start
sanitize end
copy_e820_map() start: 0000000000000000 size: 000000000009fc00 end: 000000000009fc00 type: 1
copy_e820_map() type is E820_RAM
copy_e820_map() start: 000000000009fc00 size: 0000000000000400 end: 00000000000a0000 type: 2
copy_e820_map() start: 00000000000f0000 size: 0000000000010000 end: 0000000000100000 type: 2
copy_e820_map() start: 0000000000100000 size: 0000000015eec000 end: 0000000015fec000 type: 1
copy_e820_map() start: 0000000015fec000 size: 0000000000003000 end: 0000000015fef000 type: 3
copy_e820_map() start: 0000000015fef000 size: 0000000000010000 end: 0000000015fff000 type: 2
copy_e820_map() start: 0000000015fff000 size: 0000000000001000 end: 0000000016000000 type: 4
copy_e820_map() start: 00000000ffff0000 size: 0000000000010000 end: 0000000100000000 type: 2
BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
BIOS-e820: 0000000000100000 - 0000000015fec000 (usable)
BIOS-e820: 0000000015fec000 - 0000000015fef000 (ACPI data)
BIOS-e820: 0000000015fef000 - 0000000015fff000 (reserved)
BIOS-e820: 0000000015fff000 - 0000000016000000 (ACPI NVS)
BIOS-e820: 00000000ffff0000 - 0000000100000000 (reserved)
0MB HIGHMEM available.
351MB LOWMEM available.
Using x86 segment limits to approximate NX protection
Entering add_active_range(0, 0, 90092) 0 entries of 256 used
Zone PFN ranges:
DMA 0 -> 4096
Normal 4096 -> 90092
HighMem 90092 -> 90092
early_node_map[1] active PFN ranges
0: 0 -> 90092
On node 0 totalpages: 90092
DMA zone: 32 pages used for memmap
DMA zone: 0 pages reserved
DMA zone: 4064 pages, LIFO batch:0
Normal zone: 671 pages used for memmap
Normal zone: 85325 pages, LIFO batch:15
HighMem zone: 0 pages used for memmap
DMI 2.3 present.
Using APIC driver default
ACPI: RSDP (v000 ASUS ) @ 0x000f71d0
ACPI: RSDT (v001 ASUS CUV4X_E 0x30303031 MSFT 0x31313031) @ 0x15fec000
ACPI: FADT (v001 ASUS CUV4X_E 0x30303031 MSFT 0x31313031) @ 0x15fec080
ACPI: BOOT (v001 ASUS CUV4X_E 0x30303031 MSFT 0x31313031) @ 0x15fec040
ACPI: DSDT (v001 ASUS CUV4X_E 0x00001000 MSFT 0x0100000b) @ 0x00000000
ACPI: PM-Timer IO Port: 0xe408
Allocating PCI resources starting at 20000000 (gap: 16000000:e9ff0000)
Detected 933.137 MHz processor.
Built 1 zonelists. Total pages: 89389
Kernel command line: ro root=/dev/VolGroup00/LogVol00 rhgb quiet
Local APIC disabled by BIOS -- you can enable it with "lapic"
mapped APIC to ffffd000 (012c4000)
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
Initializing CPU#0
CPU 0 irqstacks, hard=c0720000 soft=c071f000
PID hash table entries: 2048 (order: 11, 8192 bytes)
Console: colour VGA+ 80x25
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Memory: 351236k/360368k available (2090k kernel code, 8580k reserved, 846k data, 232k init, 0k highmem)
virtual kernel memory layout:
fixmap : 0xfff9b000 - 0xfffff000 ( 400 kB)
pkmap : 0xff800000 - 0xffc00000 (4096 kB)
vmalloc : 0xd6800000 - 0xff7fe000 ( 655 MB)
lowmem : 0xc0000000 - 0xd5fec000 ( 351 MB)
.init : 0xc06e0000 - 0xc071a000 ( 232 kB)
.data : 0xc060abd5 - 0xc06de614 ( 846 kB)
.text : 0xc0400000 - 0xc060abd5 (2090 kB)
Checking if this processor honours the WP bit even in supervisor mode... Ok.
Calibrating delay using timer specific routine.. 1867.37 BogoMIPS (lpj=933685)
Security Framework v1.0.0 initialized
SELinux: Initializing.
SELinux: Starting in permissive mode
selinux_register_security: Registering secondary module capability
Capability LSM initialized as secondary
Mount-cache hash table entries: 512
CPU: After generic identify, caps: 0383f9ff 00000000 00000000 00000000 00000000 00000000 00000000
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 256K
CPU: After all inits, caps: 0383f1ff 00000000 00000000 00000040 00000000 00000000 00000000
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Pentium III (Coppermine) stepping 06
Checking 'hlt' instruction... OK.
ACPI: Core revision 20060707
ACPI: setting ELCR to 0200 (from 0a20)
NET: Registered protocol family 16
ACPI: bus type pci registered
PCI: PCI BIOS revision 2.10 entry at 0xf0d00, last bus=1
PCI: Using configuration type 1
Setting up standard PCI resources
ACPI: Interpreter enabled
ACPI: Using PIC for interrupt routing
ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11 12 14 15)
ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 11 12 14 15) *0, disabled.
ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 9 10 11 12 14 15)
ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 *9 10 11 12 14 15)
ACPI: PCI Root Bridge [PCI0] (0000:00)
PCI: Probing PCI hardware (bus 00)
ACPI: Assume root bridge [\_SB_.PCI0] bus is 0
0000:00:04.1: cannot adjust BAR0 (not I/O)
0000:00:04.1: cannot adjust BAR1 (not I/O)
0000:00:04.1: cannot adjust BAR2 (not I/O)
0000:00:04.1: cannot adjust BAR3 (not I/O)
PCI quirk: region e800-e80f claimed by vt82c686 SMB
Boot video device is 0000:01:00.0
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCI1._PRT]
Linux Plug and Play Support v0.97 (c) Adam Belay
pnp: PnP ACPI init
pnp: PnP ACPI: found 14 devices
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
PCI: Using ACPI for IRQ routing
PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
NetLabel: Initializing
NetLabel: domain hash size = 128
NetLabel: protocols = UNLABELED CIPSOv4
NetLabel: unlabeled traffic allowed by default
pnp: 00:03: ioport range 0xe400-0xe47f could not be reserved
pnp: 00:03: ioport range 0xe800-0xe80f has been reserved
PCI: Bridge: 0000:00:01.0
IO window: d000-dfff
MEM window: f8800000-fa7fffff
PREFETCH window: fbf00000-fbffffff
PCI: Setting latency timer of device 0000:00:01.0 to 64
NET: Registered protocol family 2
IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
TCP established hash table entries: 16384 (order: 6, 262144 bytes)
TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
TCP: Hash tables configured (established 16384 bind 8192)
TCP reno registered
checking if image is initramfs... it is
Freeing initrd memory: 1697k freed
Simple Boot Flag at 0x3a set to 0x1
apm: BIOS version 1.2 Flags 0x03 (Driver version 1.16ac)
apm: overridden by ACPI.
audit: initializing netlink socket (disabled)
audit(1178094502.866:1): initialized
Total HugeTLB memory allocated, 0
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
SELinux: Registering netfilter hooks
ksign: Installing public key data
Loading keyring
- Added public key D3BB369FB6BCEEF7
- User ID: Red Hat, Inc. (Kernel Module GPG key)
io scheduler noop registered
io scheduler anticipatory registered
io scheduler deadline registered
io scheduler cfq registered (default)
PCI: Disabling Via external APIC routing
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
ACPI: CPU0 (power states: C1[C1] C2[C2])
ACPI: Processor [CPU0] (supports 16 throttling states)
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Real Time Clock Driver v1.12ac
Non-volatile memory driver v1.2
Linux agpgart interface v0.101 (c) Dave Jones
agpgart: Detected VIA Apollo Pro 133 chipset
agpgart: AGP aperture is 32M @ 0xfc000000
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
00:0a: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
00:0b: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 16384K size 4096 blocksize
input: Macintosh mouse button emulation as /class/input/input0
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 0000:00:04.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c686b (rev 40) IDE UDMA100 controller on pci0000:00:04.1
ide0: BM-DMA at 0xb800-0xb807, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xb808-0xb80f, BIOS settings: hdc:pio, hdd:DMA
Probing IDE interface ide0...
hda: WDC WD400BB-00AUA1, ATA DISK drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Probing IDE interface ide1...
hdd: ATAPI 44X CDROM, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
hda: max request size: 128KiB
hda: 78165360 sectors (40020 MB) w/2048KiB Cache, CHS=65535/16/63<6>hda: hw_config=604d
, UDMA(100)
hda: cache flushes not supported
hda: hda1 hda2
ide-floppy driver 0.99.newide
usbcore: registered new interface driver libusual
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
drivers/usb/input/hid-core.c: v2.6:USB HID core driver
PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
serio: i8042 KBD port at 0x60,0x64 irq 1
serio: i8042 AUX port at 0x60,0x64 irq 12
mice: PS/2 mouse device common for all mice
input: AT Translated Set 2 keyboard as /class/input/input1
TCP bic registered
Initializing XFRM netlink socket
NET: Registered protocol family 17
Using IPI Shortcut mode
Time: tsc clocksource has been installed.
ACPI: (supports S0 S1 S4 S5)
Freeing unused kernel memory: 232k freed
Write protecting the kernel read-only data: 585k
Time: acpi_pm clocksource has been installed.
logips2pp: Detected unknown logitech mouse model 1
input: PS/2 Logitech Mouse as /class/input/input2
device-mapper: ioctl: 4.11.0-ioctl (2006-10-12) initialised: dm-devel@redhat.com
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: dm-0: orphan cleanup on readonly fs
ext3_orphan_cleanup: deleting unreferenced inode 4288474
EXT3-fs: dm-0: 1 orphan inode deleted
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: Disabled at runtime.
SELinux: Unregistering netfilter hooks
audit(1178094510.754:2): selinux=0 auid=4294967295
input: PC Speaker as /class/input/input3
via686a 0000:00:04.4: base address not set - upgrade BIOS or use force_addr=0xaddr
Linux video capture interface: v2.00
hdd: ATAPI 40X CD-ROM drive, 128kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
PCI: Enabling device 0000:00:05.0 (0084 -> 0085)
ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
PCI: setting IRQ 5 as level-triggered
ACPI: PCI Interrupt 0000:00:05.0[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
PCI: Enabling device 0000:00:0b.0 (0004 -> 0006)
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
PCI: setting IRQ 11 as level-triggered
ACPI: PCI Interrupt 0000:00:0b.0[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
bttv0: Bt878 (rev 17) at 0000:00:0b.0, irq: 11, latency: 32, mmio: 0xfb000000
bttv0: detected: Hauppauge WinTV [card=10], PCI subsystem ID is 0070:13eb
bttv0: using: Hauppauge (bt878) [card=10,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffdb [init]
bttv0: Hauppauge/Voodoo msp34xx: reset line init [5]
tveeprom 1-0050: Hauppauge model 44801, rev D182, serial# 7229303
tveeprom 1-0050: tuner model is LG TAPC H791F (idx 82, type 39)
tveeprom 1-0050: TV standards NTSC(M) (eeprom 0x08)
tveeprom 1-0050: audio processor is None (idx 0)
tveeprom 1-0050: has no radio
bttv0: Hauppauge eeprom indicates model#44801
bttv0: using tuner=39
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
tuner 1-0061: chip found @ 0xc2 (bt878 #0 [sw])
tuner 1-0061: type set to 39 (LG NTSC (newer TAPC series))
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
PCI: setting IRQ 9 as level-triggered
ACPI: PCI Interrupt 0000:00:09.0[A] -> Link [LNKD] -> GSI 9 (level, low) -> IRQ 9
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
0000:00:09.0: 3Com PCI 3c905C Tornado at d6946000.
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
PCI: Enabling device 0000:00:0b.1 (0004 -> 0006)
ACPI: PCI Interrupt 0000:00:0b.1[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
bt878_probe: card id=[0x13eb0070], Unknown card.
Exiting..
ACPI: PCI interrupt for device 0000:00:0b.1 disabled
bt878: probe of 0000:00:0b.1 failed with error -22
PCI: Enabling device 0000:00:07.0 (0004 -> 0005)
ACPI: PCI Interrupt 0000:00:07.0[A] -> Link [LNKB] -> GSI 11 (level, low) -> IRQ 11
parport_pc: VIA 686A/8231 detected
parport_pc: probing current configuration
parport_pc: Current parallel port base: 0x378
parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
parport_pc: VIA parallel port: io=0x378, irq=7
USB Universal Host Controller Interface driver v3.0
ACPI: PCI Interrupt 0000:00:04.2[D] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
uhci_hcd 0000:00:04.2: UHCI Host Controller
uhci_hcd 0000:00:04.2: new USB bus registered, assigned bus number 1
uhci_hcd 0000:00:04.2: irq 5, io base 0x0000b400
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ACPI: PCI Interrupt 0000:00:04.3[D] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
uhci_hcd 0000:00:04.3: UHCI Host Controller
uhci_hcd 0000:00:04.3: new USB bus registered, assigned bus number 2
uhci_hcd 0000:00:04.3: irq 5, io base 0x0000b000
usb usb2: configuration #1 chosen from 1 choice
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
usb 1-2: new full speed USB device using uhci_hcd and address 2
usb 1-2: configuration #1 chosen from 1 choice
codec write timeout, status = 0x60
usbcore: registered new interface driver snd-usb-audio
lp0: using parport0 (interrupt-driven).
lp0: console ready
input: Power Button (FF) as /class/input/input4
ACPI: Power Button (FF) [PWRF]
input: Power Button (CM) as /class/input/input5
ACPI: Power Button (CM) [PWRB]
No dock devices found.
ibm_acpi: ec object not found
md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
EXT3 FS on dm-0, internal journal
EXT3 FS on hda1, internal journal
Adding 720888k swap on /dev/VolGroup00/LogVol01. Priority:-1 extents:1 across:720888k
ip_tables: (C) 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
nf_conntrack version 0.5.0 (2815 buckets, 22520 max)
eth0: setting full-duplex.
Bluetooth: Core ver 2.11
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.8
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
Mobile IPv6
eth0: no IPv6 routers present
bttv0: PLL can sleep, using XTAL (28636363).
So I even tried using vbi0 as the source for the USBcam but still nothing.
Posted: Wed May 02, 2007 11:15 pm
by jameswilson
I might be missing the question here lol
But im assuming your trying to get this to work before getting it into zm. If so your going the right way. If linux has detected it it should give it a device name like vid 1 etc as you have noted, but if its not loading correctly it wont. You sure it supported?
Posted: Wed May 02, 2007 11:35 pm
by cordel
The drivers for this camera are either not in the kernel (most likely) or that model just is not supported yet. Since dmesg does not show the usb camera, you will not have a device link for it. I googled a bit for you but came up with a driver that has alpha support for your device http://linux-uvc.berlios.de/
