Page 1 of 1
Zoneminder Feisty Fawn Ubuntu 7.0.4
Posted: Thu May 03, 2007 4:31 am
by oslick
There are two .deb packages on the zoneminder site. One for draper one for edgy. Can I use these for the newer Feisty Fawn, or should I compile it myself
Posted: Thu May 03, 2007 10:28 pm
by PeterHoward
You're the second person to ask today :)
Feel free to build it yourself, otherwise I hope to build (and do "sanity-check" testing only) for Feisty over the weekend.
Posted: Fri May 04, 2007 1:27 pm
by John Williams
I just did a fresh install on a new feisty install with the latest edgy zm deb. Worked fine, with a simple workaround. See the wiki, where I updated it with instructions for feisty... I did not include camera info, since that can be situation specific. I am running a cheapo BT878 card and can give additional info on how to get that running.
Let me know if it needs amplification...
Posted: Sun May 06, 2007 3:01 am
by PeterHoward
John Williams wrote:I just did a fresh install on a new feisty install with the latest edgy zm deb. Worked fine, with a simple workaround. See the wiki, where I updated it with instructions for feisty... I did not include camera info, since that can be situation specific. I am running a cheapo BT878 card and can give additional info on how to get that running.
If the workaround was the reconfigure of /bin/sh from dash to bash, then I'm concerned. One of the main points of my -6 release was to get things working with dash. Can you tell me what errors you were getting?
PJH
Posted: Mon May 07, 2007 1:27 pm
by John Williams
Did a re-test on Feisty and the dash fix is working, so updated the wiki. Only workaround now is to change nph_zms to zms so that I get reliable streaming for localhost., and I had to add www_data to the video group to allow access without chmod every reboot.
BTW, running Xen on feisty so real easy to boot guest edgy and feisty versions to test stuff...
