I'm seeing double :)
Posted: Sat May 05, 2007 3:25 am
So tonight I moved over my 4-port CCTV board from my Win2k system to my FC3 system running ZM 1.22. It picked up the card fine on the first try, and I didn't need to tweak anything significant yet. I had to increase shared memory, which is of course all over these boards and the FAQ.
Here's my new issue...I couldn't find anything in the forums that matches this problem...
When I switch a camera from 320x200 to 640x480, I get a 320x200 image TWICE, side-by-side, rather than a hires single image. The board is capable of higher. Here is the output from zmu:
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 200
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
If I'm reading that correctly, it should do 768x480. Why am I just getting 2 side-by-side copies of the same picture, rather than a single hires one? Is there a setting somewhere to override the board to get hires?
Thanks in advance for any input....
Video Capabilities
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 200
Picture Attributes
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
