When I change paths video does not play
3gem
Post by 3gem »
I have installed ZM using the fedora step by step in the wiki. The install works great.
When I change the path for events, sounds and images it fails to stream the video. I created a dir called cctv and did a chown apache:apache . I stopped and started the service, but no change. If I change it back to the default then it works again.
Thanks in advance.
-Gregg
cordel
Post by cordel »
Rather than change the path in ZM, just link events to your cctv and make sure that apache is setup to FollowSymLinks.
3gem
Post by 3gem »
ok here is what I did
I removed the existing folders in /var/www/html/zm
then create new ones like ln -s /pathtodir/events events? ect..
and I have Options FollowSymLinks in my httpd.conf
Still does not work am I missing something?
cordel
Post by cordel »
Do you have the correct permisions set on those folders and links so that apache has access?
3gem
Post by 3gem »
duh.... sorry bonehead mistake. Changed permissions. Thanks!!!
