Jumpy Black And White picture
Smokey
Post by Smokey »
Hoping someone can suggest a solution to my issue.
I have recently purchased a PV149 from Bluecherry and I am having issues with picture colour/quality. I am using Bluecherry's latest LiveCD and a single PAL/NTSC wireless camera and have checked to make sure it is sending a signal by plugging it into my LCD tv on which I observe a good picture. The picture I get in Zoneminder is black and white and very jumpy with a black border on the left side of the picture which flickers in and out as the picture jumps.
Prior to purchasing the PV149 I was using a cheap DVR card I purchased on Ebay which I experienced the exact same issue with. The only difference in this case was that I was using the 1.22.3 Ubuntu Live CD download from the Zoneminder downloads section.
I am using a Compaq Evo Deskpro with a 2.4 Pentium and 512mb RAM.
Can anyone offer an opinion as to what the issue might be. I will post a picture of my current display a little later.
jameswilson
Post by jameswilson »
if you want us to support you use either the live cd ir ctu zm, if you want to use the bluecherry distro contect them
James Wilson
Smokey
Post by Smokey »
I've used both distro's with the same result which is what I've stated above. I was hoping that someone could kindly offer any suggestions as to what the issue is.
jameswilson
ok then smokey if your on the live cd whats in your logs?
James Wilson
maclellan
Post by maclellan »
Is the picture also shifting left and right? If so I have the same problem.
