start and stop not functionaing
nelius
Post by nelius »
Hi
If I click the start button on top of the control-page, nothing happens, it remains as stop, and nothing comes in the log-files.
If i then open a watch-window, i can see no video, in the logs is said, that zmc has not initialized shared mem.
If i try to activate this cam, the logs says: permission denid vor /dev/video0
to get the thing solved, i hav to run zmc -d 0, than it works, exept the stop button then...
whats going wrong?
tnx
cornelius
nelius
Re: start and stop not functionaing
Post by nelius »
Ok, i found it,
It was the wrong user and group for apache...
mikep
Post by mikep »
yes, in /usr/bin/zmpkg.pl theres the web username and password, they have to match.
I just did that and it seemed to help a lot as well.
mikep
Post by mikep »
it was failing because of
Can't open log file: Permission denied at /usr/bin/zmdc.pl line 153.
I just put a absolute path to /tmp/zmdc.log instead because it couldnt access /var/log.
works now says its running!
