Bug creating video
santifer
Bug creating video
Post by santifer »
Hi.
I'm using a installed Mandriva LiveCD, and when I select a Event, I generate a video and it generates well, but when I try to regenerate it (selecting the option "Overwrite existing video") with any format it says me that there it was an error creating the Video.
¿Does it happens to you? ¿It's a bug?
Thanks.
zoneminder
Site Admin
Post by zoneminder »
Can you check you zmvideo.log file and also your httpd error log and see if anything is generated in there when you get the error.
Phil
