Page 1 of 1
Toshiba IK-WB02A mjpeg stream URL
Posted: Sat May 12, 2007 4:43 pm
by ryan_marsh
I am not having any luck with the recommended URL's for the Toshiba cameras. Does anyone have any experience with the IK-WB02A?
Posted: Sat May 12, 2007 5:16 pm
by ryan_marsh
After using ethereal I found that the URL for the stream is
http://192.168.1.30/GetData.cgi?Status=1 which works in my browser. However zm is not grabbing anything.
Posted: Sat May 12, 2007 5:23 pm
by ryan_marsh
FYI this is how the stream starts (from wget'ting the url)
--WINBONDBOUDARY^M
Content-Type: image/jpeg^M
^M
ÿØÿâ^@^FE^R^^Áÿç^@^D^@^@ÿÛ^@C^@ ^G^H ^H^G
^H ^H^L^K^H^O^R^\^Q^P^O^O^P"^V^_^R^\"'("$&(((2:2(/</$$8G9<@ADDD(0IMHBL>CD@ÿÛ^@C^A^H^H^H
^T^Q^Q^T*^\^X^\**************************************************ÿÄ^@^_^@^@^A^E^A^A^A^A^A^A^@^@^@^@^@^@^@^@^A^B^C^D^E^F^G^H
Posted: Sun May 20, 2007 12:37 am
by pathway
I don't get the stream. I get the jpeg image.
/Jpeg/CamImg.jpg
Never had a problem with it.
Question though, do you find the image on the WB02A a bit... "fuzzy"? Also, do you loose focus at night?
--Pathway
Posted: Sun May 20, 2007 10:09 pm
by ryan_marsh
Yes, it's certainly not a crappy camera but it's not a Bosch either.
Posted: Tue Mar 18, 2008 4:33 am
by socsuser
I appear to be having some problems here with this camera. I suspect that it is the configuration. Any help would be much appreciated.
The camera works just fine through the browser and the ZoneMinder box is communicating with the camera in the sense that I can ping it. The cameras are operating from PoE.
General:
Source Type: Remote
Function: Monitor
Enabled: Checked
Linked Monitors: <blank>
Maximum FPS: 30
Alarm Maximum FPS: 30
Ref Image Blend %ge: 7
Triggers: None Available
Source:
Remote Host Name: 192.168.0.51
Remote Host Port: 80
Remote Host Path: /Jpeg/CamImg.jpg
Remote Image: 24 bit colour
Capture Width: 640
Capture Height: 480
Preserve Aspect Ratio: Checked
Orientation: Normal
All of the remaining tabs are set to default options.
What could be going on here?
Posted: Wed Mar 19, 2008 12:31 pm
by socsuser
Also, just an FYI, the url "http://###.###.###.###/Jpeg/CamImg.jpg" is yielding an image from the camera, it is simply that ZoneMinder is not pulling up the image it appears and I could very much use some assistance in troubleshooting as soon as possible.
Posted: Wed Mar 19, 2008 1:50 pm
by ryan_marsh
which model camera is this?
Posted: Wed Jul 29, 2009 7:43 pm
by paoletto
Sorry for resuming this thread.
I got this camera recently. I tried to get it to work by using a 12V 1A DC power supply connected to the 2 + - screws in the back (no ground)
but apparently the camera is dead.. not even the weakest whisper from it. it remains cold. i try to plug in the ethernet cable and the pc says the link is down, and the leds behind the camera remain off..
the camera was brand new sealed in box. is it possible it is broken or am i just using the wrong power supply? yes, i have the power switch to 12/24 not to PoE, and yes i think the PSU works. i couldnt check since i havent a voltemeter, but it has a led and it is on when it is plugged to the power line
any suggestion?
yes its dead
Posted: Wed Jul 29, 2009 7:49 pm
by ryan_marsh
I have received several of these dead from the factory. Call Toshiba directly about it. They will get one too you faster than your wholesaler probably can.
Posted: Sat Jan 23, 2010 11:26 am
by paoletto
thank you very much ryan!
it has been quite a problem to get it replaced, but it was in fact broken, and now it works fine
