I have this card http://www.visualwall.com/pro_view/dvr/ ... r-430b.htm
I have put in /etc/modprobe.conf
options bttv card=77 tuner=4
but it work only channel 0!
If I add new camera /dev/video (with cannel 0 it work)
If I add new camera /dev/video (with cannel 1 it don't work)
Chip is conexant fusion 878A
Any idea?Thank you
scanpci -v
pci bus 0x0000 cardnum 0x08 function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
CardVendor 0x6a61 card 0x6b68 (Card unknown)
STATUS 0x0290 COMMAND 0x0006
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xed002008 addr 0xed002000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0000 cardnum 0x08 function 0x01: vendor 0x109e device 0x0878
Brooktree Corporation Bt878 Audio Capture
STATUS 0x0290 COMMAND 0x0002
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xed000008 addr 0xed000000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0a
xawtv -hwscan
/dev/video0: OK [ -device /dev/video0 ]
type : v4l2
name : BT878 video (Grand X-Guard / Tr
flags: overlay capture
/usr/lib/zm/bin/zmu -d /dev/video0 -q -v
Video Capabilities
Name: BT878 video (Grand X-Guard / Tr
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 16
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 380
Height: 288
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 4 Attributes
Channel: 4
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 5 Attributes
Channel: 5
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 6 Attributes
Channel: 6
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 7 Attributes
Channel: 7
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 8 Attributes
Channel: 8
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 9 Attributes
Channel: 9
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 10 Attributes
Channel: 10
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 11 Attributes
Channel: 11
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 12 Attributes
Channel: 12
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 13 Attributes
Channel: 13
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 14 Attributes
Channel: 14
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 15 Attributes
Channel: 15
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:00:09.0, irq: 10, latency: 32, mmio: 0xed002000
bttv0: subsystem: 6a61:6b68 (UNKNOWN)
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00f7feff [init]
bttv0: using tuner=4
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
bt878_probe: card id=[0x6b686a61], Unknown card.
bt878: probe of 0000:00:09.1 failed with error -22
