The pan/tilt speed seems to have no effect, and I don't have an auto-iris, or zoom lens, so I can't verify that those commands work.
Presets have never worked for me, even in the native interface. The camera just seems to go into a continuous pan back and forward forever.
As the movement is continuous only, I'm not entirely sure that this is correct. I can't seem to get the autostop to work. On the cameras native interface the movement is stopped by an "onmouseup" event, ie. to move the camera you must hold down the movement buttons. Have I missed something and can zoneminder do this itself?
#!/usr/bin/perl -wT
# ZoneMinder Panasonic IP Camera Control Script, $Date: 2006/05/08 12:37:48 $, $Revision: 1.5 $
# Copyright (C) 2003, 2004, 2005, 2006 Philip Coombes
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
use strict;
# These are the elements you can edit to suit your installation
use constant DBG_ID => "zmctrl-gadip"; # Tag that appears in debug to identify source
use constant DBG_LEVEL => 0; # 0 is errors, warnings and info only, > 0 for debug
use ZoneMinder;
use Getopt::Long;
$| = 1;
$ENV{PATH} = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
print( "
Usage: zmcontrol-gadspot-ip.pl <various options>
exit( -1 );
zmDbgInit( DBG_ID, level=>DBG_LEVEL );
my $arg_string = join( " ", @ARGV );
my $address;
my $command;
my ( $speed, $step );
my ( $xcoord, $ycoord );
my ( $width, $height );
my ( $panspeed, $tiltspeed );
my ( $panstep, $tiltstep );
my $preset;
my $autostop;
if ( !GetOptions(
'address=s'=>\$address,
'command=s'=>\$command,
'autostop=f'=>\$autostop,
'speed=i'=>\$speed,
'step=i'=>\$step,
'xcoord=i'=>\$xcoord,
'ycoord=i'=>\$ycoord,
'width=i'=>\$width,
'height=i'=>\$height,
'panspeed=i'=>\$panspeed,
'tiltspeed=i'=>\$tiltspeed,
'panstep=i'=>\$panstep,
'tiltstep=i'=>\$tiltstep,
'preset=i'=>\$preset
Usage();
if ( !$address )
Usage();
if ( defined($autostop) )
# Convert to microseconds.
$autostop = int(1000000*$autostop);
Debug( $arg_string."\n" );
srand( time() );
sub printMsg
my $msg = shift;
my $msg_len = length($msg);
Debug( $msg."[".$msg_len."]\n" );
sub sendCmd
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
use LWP::UserAgent;
my $ua = LWP::UserAgent->new;
$ua->agent( "ZoneMinder Control Agent/".ZM_VERSION );
#print( "http://$address/$cmd\n" );
my $req = HTTP::Request->new( GET=>"http://$address/$cmd" );
my $res = $ua->request($req);
if ( $res->is_success )
$result = !undef;
else
Error( "Error check failed: '".$res->status_line()."'\n" );
return( $result );
sub moveUp
Debug( "Move Up\n" );
my $cmd = "PTZCmd.cgi?Cmd=UP";
sendCmd( $cmd );
if ( $autostop )
usleep( $autostop );
stop();
sub moveDown
Debug( "Move Down\n" );
my $cmd = "PTZCmd.cgi?Cmd=DOWN";
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveLeft
Debug( "Move Left\n" );
my $cmd = "PTZCmd.cgi?Cmd=LEFT";
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveRight
Debug( "Move Right\n" );
my $cmd = "PTZCmd.cgi?Cmd=RIGHT";
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveUpRight
my $cmd = "PTZCmd.cgi?Cmd=RIGHT_UP";
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveUpLeft
my $cmd = "PTZCmd.cgi?Cmd=LEFT_UP";
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveDownRight
my $cmd = "PTZCmd.cgi?Cmd=RIGHT_DOWN";
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveDownLeft
my $cmd = "PTZCmd.cgi?Cmd=LEFT_DOWN";
sendCmd( $cmd );
if ( $autostop )
stop();
sub setSpeed
Debug( "Set Speed\n");
my $cmd = "SetPTZ.cgi?Speed=$panspeed";
sendCmd( $cmd );
sub stop
Debug( "STOP\n" );
my $cmd = "PTZCmd.cgi?Cmd=STOP";
sendCmd( $cmd );
sub zoomTele
Debug( "Zoom Tele\n" );
my $cmd = "PTZCmd.cgi?Cmd=ZOOM_TELE";
sendCmd( $cmd );
if ( $autostop )
stop();
sub zoomWide
Debug( "Zoom Wide\n" );
my $cmd = "PTZCmd.cgi?Cmd=ZOOM_WIDE";
sendCmd( $cmd );
if ( $autostop )
stop();
sub focusNear
Debug( "Focus Near\n" );
my $cmd = "PTZCmd.cgi?Cmd==FOCUS_NEAR";
sendCmd( $cmd );
if ( $autostop )
stop();
sub focusFar
Debug( "Focus Far\n" );
my $cmd = "PTZCmd.cgi?Cmd=FOCUS_FAR";
sendCmd( $cmd );
if ( $autostop )
stop();
sub focusAuto
Debug( "Focus Auto\n" );
my $cmd = "PTZCmd.cgi?Cmd=FOCUS_AUTO";
sendCmd( $cmd );
sub irisClose
Debug( "Iris Close\n" );
my $cmd = "PTZCmd.cgi?Cmd=IRIS_CLOSE";
sendCmd( $cmd );
if ( $autostop )
stop();
sub irisOpen
Debug( "Iris Open\n" );
my $cmd = "PTZCmd.cgi?Cmd=IRIS_OPEN";
sendCmd( $cmd );
if ( $autostop )
stop();
sub irisAuto
Debug( "Iris Auto\n" );
my $cmd = "PTZCmd.cgi?Cmd=IRIS_AUTO";
sendCmd( $cmd );
sub presetClear
my $preset = shift || 1;
Debug( "Clear Preset $preset\n" );
my $cmd = "nphPresetNameCheck?Data=$preset";
sendCmd( $cmd );
sub presetSet
Debug( "Set Preset $preset\n" );
my $cmd = "PTZCmd.cgi?Cmd=SET_PRESET&PresetID=$preset";
sendCmd( $cmd );
sub presetGoto
Debug( "Goto Preset $preset\n" );
my $cmd = "PTZCmd.cgi?Cmd=CALL_PRESET&PresetID=$preset";
sendCmd( $cmd );
if ( $command eq "move_con_up" )
moveUp();
elsif ( $command eq "move_con_down" )
moveDown();
elsif ( $command eq "move_con_left" )
moveLeft();
elsif ( $command eq "move_con_right" )
moveRight();
elsif ( $command eq "move_con_upleft" )
moveUpLeft();
elsif ( $command eq "move_con_upright" )
moveUpRight();
elsif ( $command eq "move_con_downleft" )
moveDownLeft();
elsif ( $command eq "move_con_downright" )
moveDownRight();
elsif ( $command eq "move_stop" )
stop();
elsif ( $command eq "zoom_con_tele" )
zoomTele();
elsif ( $command eq "zoom_con_wide" )
zoomWide();
elsif ( $command eq "zoom_stop" )
stop();
elsif ( $command eq "focus_con_near" )
focusNear();
elsif ( $command eq "focus_con_far" )
focusFar();
elsif ( $command eq "focus_auto" )
focusAuto();
elsif ( $command eq "focus_stop" )
stop();
elsif ($command eq "iris_con_close" )
irisClose();
elsif ($command eq "iris_con_open" )
irisOpen();
elsif ($command eq "iris_auto" )
irisAuto();
elsif ( $command eq "iris_stop" )
stop();
elsif ( $command eq "preset_set" )
presetSet( $preset );
elsif ( $command eq "preset_goto" )
presetGoto( $preset );
else
Error( "Can't handle command $command\n" );
