help with hardware
namiiii
help with hardware
Post by namiiii »
I have the following hardware
http://www.swann.com.au/s/products/view/?product=379
http://www.swann.com.au/s/products/view/?product=319
I have zoneminder installed but don't know how to get the above hardware to work with it...
help
jameswilson
Post by jameswilson »
what disto you using, if its one of the official supported ones then edit /etc/modprobe.conf and add
options bttv card=77
to it
save and reboot
James Wilson
namiiii
Post by namiiii »
i have ubuntu 7.04
i tried setting it up but it still does not work
here is a screen shot
http://img527.imageshack.us/img527/5061 ... hotqm8.png
i dont know what to enter in the 5 settings tabs...
jameswilson
in the second tab you need
/dev/video0 in device path
0 in channel
pal/ntsc in format
rgb24 in pallete
360 in width
240 in height
James Wilson
namiiii
Post by namiiii »
Thanks for the reply.
I tried what you said and it didn't seem to make any difference.
I don't seem to have a video0 in my dev folder.
Here is a screenshot of the dev folder and the broken image where the camera image should be.
http://img86.imageshack.us/img86/5762/screenshotzm6.png
cordel
Post by cordel »
What does
dmesg |grep bt
show you???
namiiii
Post by namiiii »
That returns nothing.
cordel
Post by cordel »
Then the linux kernel does not see your card.
namiiii
Post by namiiii »
Is there no way to get the linux kernal to see my card?
cordel
Post by cordel »
You could try to manualy insmod the bttv drivers. Might be helpfull if we knew more about your setup though.
What distro/release?
What mainboard are you using?
Does it show the capture card on the bios post?
namiiii
Post by namiiii »
I'm using ubuntu 7.04
I don't know the answer to the rest of the question, where do I get that info from?
It's an old celeron board
cordel
Post by cordel »
The main board name and model should show up while the machine is posting(boot from bios) and same with the capture card, you should see it in a list of devices showing port and irq used.
namiiii
Post by namiiii »
The capture card I have can be seen in the very first post of this thread. I will restart my computer to get the board into.
edit ---
the motherboard seems to be a M6VCF
