I have a filter turned on to start deleting events from oldest to newest when the disk gets over 90% full. When I checked it this morning zm was down and the hard drive is full. I stopped the zm service and tried to search for events by dates and checked the box to delete the events it finds but it does not delete them.
I then search by date and check the box to delete the events and I have successfully deleted all the events for the first recorded day. When I go and check to make sure the images directory got deleted I found that they had not. Deleting the events does not free up space.
Am I doing something wrong or am I missing something. Thanks
Allan
Deleting events not freeing space
I was deleting events with the service stopped since the hard drive was full and I didn't want it to fill it up as fast as I deleted it. Now that I have started the zm service back up it is starting to clear space on the hard drive. Can someone explain a little more about how this process works. Thanks
Allan
Allan
I have a pretty old PC handling my ZoneMinder system. I found that if i set the Purge when full option too high (>= 93%) it would sometimes not purge the data out of the drive in time. What would then happen is, my PC would run out of HDD space and consequently blow a valve.
So, I would guess, that the Purge function is not instantaneous, but rather run when it gets a chance. I'm sure that when you delete events that it sends the request to another process to do the actual deletion.
I have set my Purge to 87% and have not seen a problem in about 12 months of stable operation.
Thanks, I noticed that to that was why I had it set to 90%. I should have read better through the forums but it looks like there is a new patch out there to fix this problem or at least one close to it.
http://www.zoneminder.com/forums/viewtopic.php?p=31779
Just in case anyone needs any extra notes about how to apply the patch this is what I did on my Ubuntu Edgy system.
cd /var/www/zm
sudo wget http://www.zoneminder.com/downloads/zm- ... lter.patch
sudo patch -p0 < zm-1.22.3-filter.patch
sudo chown www-data:www-data zm_actions.php
sudo chmod 644 zm_actions.php
Not sure if it will fix the deleting problem which started working before I fixed the problem but should allow me to delete events from the filter view.
Allan
cd /var/www/zm
Allan
Thanks for pointing out the fast delete. It is like my filter is never run although I did a ps aux and zmfilter.pl -c is running. To delete events I have to run the purge filter and choose execute. I do this for a few days worth of events then I have to run zmaudit.pl and it goes through and frees up the space.
Any ideas why this wouldn't be working? Thanks
Allan
Allan
