Hallo, i have problem with zoneminder 1.2.23 and IE7; I don't have streaming but this error:
Warning: require_once(zm_.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/zm/zm.php on line 191
Fatal error: require_once() [function.require]: Failed opening required 'zm_.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/zm/zm.php on line 191
With IE6 and Firefox is all ok.
An ideas? Thanks.
Sorry for my english
No stream with IE 7
In another pc i have zoneminder 1.22.2 and it's ok with IE7.
I have copy /var/www/zm/sm.php file in my computer with zoneminder 1.22.3, but i have problem again:
Warning: require_once(zm_.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/zm/zm.php on line 173
Fatal error: require_once() [function.require]: Failed opening required 'zm_.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/zm/zm.php on line 173
Can you help me?
Thanks.
Can you help me?
Thanks.
