Page 1 of 1
No stream with IE 7
Posted: Tue May 29, 2007 8:21 pm
by ilababy
Hallo, i have problem with zoneminder 1.2.23 and IE7; I don't have streaming but this error:
Warning: require_once(zm_.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/zm/zm.php on line 191
Fatal error: require_once() [function.require]: Failed opening required 'zm_.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/zm/zm.php on line 191
With IE6 and Firefox is all ok.
An ideas? Thanks.
Sorry for my english
Posted: Fri Jun 01, 2007 6:36 pm
by ilababy
Can you help me?
Thanks.
Posted: Fri Jun 01, 2007 6:56 pm
by W.
check if cookies are enabled in ie7 for your zm host.
Posted: Sun Jun 03, 2007 11:55 am
by ilababy
Yes, the cookies are enabled in ie7 for my zm host.
Have another idea?
Posted: Mon Jun 04, 2007 9:50 pm
by ilababy
In another pc i have zoneminder 1.22.2 and it's ok with IE7.
I have copy /var/www/zm/sm.php file in my computer with zoneminder 1.22.3, but i have problem again:
Warning: require_once(zm_.php) [function.require-once]: failed to open stream: No such file or directory in /var/www/zm/zm.php on line 173
Fatal error: require_once() [function.require]: Failed opening required 'zm_.php' (include_path='.:/usr/share/php:/usr/share/pear') in /var/www/zm/zm.php on line 173
Can you help me?
Thanks.
Posted: Sat Jun 09, 2007 12:34 am
by cordel
You can not place files from diferent versions on the system. It will break it.
You must have something setup (or not setup as the case may be) in IE7 to keep it from working as mine here works fine with 1.22.3. Check your securities in IE7.
