Page 1 of 1
Question on video card with 4 inputs
Posted: Fri Jun 01, 2007 4:49 pm
by tnats
This software is great. I have a video capture card with 4 inputs. If I plug the first camera into port 0, it works great. But, when I add an additional camera to port #1, I get no picture. I tried for 2 and 3 with no luck. Any of how I can add more cameras? Thanks.
Video Capabilities
Name: BT878 video ( *** UNKNOWN/GENER
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 1
Maximum Width: 768
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 3
Channel has a tuner
Channel has audio
Type: 1 - TV
Format: 1 - NTSC
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 1 - NTSC
Posted: Fri Jun 01, 2007 5:06 pm
by Lee Sharp
cd to /dev and type 'ls vi*' and tell us what you see. If you have /dev/video0 to /dev/video4 you do it one way. If you only have /dev/video0 you do it another way. Depending on the card, you may also need a modprobe line.
Posted: Fri Jun 01, 2007 5:46 pm
by boycho
input=0, input=1,input=2,input=3
or Device Channel 0(1,2,3) for ZM
Posted: Fri Jun 01, 2007 6:03 pm
by tnats
root@cctv:/dev# ls -l vid*
crw-rw-rw- 1 root video 81, 0 2007-06-01 10:26 video0
Sorry Boycho, I don't understand what you are saying there. Is it a setting in the GUI?
Posted: Fri Jun 01, 2007 6:08 pm
by boycho
FOR ZM
Tab Source:
for cam 1 - Device Path /dev/video0
Device Channel 0
for cam 2 - Device Path /dev/video0
Device Channel 1
for cam 3 - Device Path /dev/video0
Device Channel 2
for cam 4 - Device Path /dev/video0
Device Channel 3
FOR Mplayer
-tv device=/dev/video0:input=(0 , or 1 , or 2 , or 3)
Posted: Fri Jun 01, 2007 6:57 pm
by tnats
Oops, I had /dev/video instead of /dev/video0 for the 2nd camera. Works great now!
Thanks for your help.
-Tom
