it driove me nuts - now I'm happy again
Posted: Sun Jun 03, 2007 1:46 pm
Hello you Linux guru's out there - I need your help.
some months ago I installed zoneminder on Ubuntu 6.10 following the insructions on the ZM-Wiki.
Everything worked great and I started already to adjust the zones to get alarms when any cats (or other animals) got close to my Koi-Pond.
Well - I know: Never touch a running system - but I did it anyway and upgraded Ubuntu to 7.04 and Zoneminder stopped working. I played around for many weekends - but no success until now.
I removed the 'old' build from the system and deleted everything which smelled like ZM and tried my luck with the ZM deb package.
Already during installation I've got following error message
Starting ZoneMinder: sudo: /usr/local/bin/zmdc.pl: command not found
After doing some investigation I found, that the installer put all the files into /usr/bin/ - no wonder that it caused problems. Also the zmpkg.log shows complaints about the missing zmdc.pl file in /usr/local/bin/
I can open up the ZM-Console but Zoneminder status is 'Stopped' and there is no way to start it. Also the Source device /dev/video0 is shown in RED color.
I can watch the camera output via XawTV without any problem.
Has anyone a hint for a Linux-Beginner? It is so frustrating not making any progress
Greetings
from Wiesbaden/Germany
Greetings
