So I have a copy of zm that was working great with a quickcam pro 4000.
I'm trying to set up a Logitech quickcam Chat.
I have it all working and i can view through the camera and everything except that the brightness and contrast insist on being set wrong.
I can click on "settings" from the monitor window and I am provided with a window that lets you change the brightness and contrast by entering largish integers (in the 10 to 20 thousand range). When I change those numbers the camera looks good for about 1 second, then the numbers revert back to what they were (or close to what they were, sometimes it's a little different number).
1) open settings window
2) brightness says (for example) 20000
3) type 10000, hit save
4) picture looks good for 1 second, then brightness number changes to 19673 (for example)
5) picture is crappy again.
It's like something else is changing the numbers back to what they were. Is there some way I can force those brightness/contrast settings to stay as what I set them to be?
OS is Ubuntu Feisty, install was from a tarball (ZoneMinder-1.22.3.tar.gz).
Thanks![/url]
