Page 1 of 1
got this camera, what options do i have?
Posted: Wed Jun 06, 2007 10:38 am
by vaineh
hi all,
got this camera for free
http://www.digitalvideos.co.uk/default. ... &txtid=935
and want to hook it upto zoneminder which just has a usb camera on it at the moment. its got a bnc connection, what options do i have in the uk to plug it into a pc. i cant find any bnc capture cards.
Posted: Fri Jun 08, 2007 10:23 am
by vaineh
http://www.eclipsecomputers.com/product ... P878&af=50
where it says
# Recording Rate : 16~30fps (NTSC), 12~25fps (PAL) (depend on CPU speed and channel)
# Display Rate : 30 fps (NTSC), 25fps (PAL) Video Resolution : 320 x 240 Compression Format : MJPEG (software compression)
does that mean in total? so 25 / 4 for each camera? or do you reckon thats the fps per channel?
Posted: Fri Jun 08, 2007 4:33 pm
by cordel
Thats total fps for the combined cameras. Also with switching and resync, you can expect when using all four inputs ~2.5 FPS on each camera.
