round robin - possible or not?
mangoo
Post by mangoo »
I have several network cameras, but I'd like to stream video from them using only one "capture window" / one MJPEG image - thus, one stream should just change the cameras after another, or round-robin (every few seconds).
There was a similar topic about "round robin" subject:
http://www.zoneminder.com/forums/viewtopic.php?t=5658
but still I'm not sure it's very related, it didn't bring clear answers to my question.
mangoo
Post by mangoo »
All right, I guess that's what "Cycle" provides :)
However - "Cycle" only streams in MJPEG, not in MPEG - is it possible to change it?
I want to stream video from several cameras in this round-robin fashion on a website; using MJPEG takes just too much bandwidth.
I could transcode MPEG on-the-fly with VLC to use less bandwidth.
It's also possible to transcode MJPEG on-the-fly with VLC - but when we use "Cycle", MJPEG picture link changes when the cameras are cycled.
Solutions?
cordel
Post by cordel »
You will find those setting in options and is covered in the manual.
mangoo
Post by mangoo »
cordel wrote:You will find those setting in options and is covered in the manual.
Really? I can indeed set MPEG streaming, but it only works for:
1) viewing separate cameras (i.e, when we click on a camera name)
2) viewing "montage" - all cameras on one page
For "cycle", MPEG streaming just doesn't work - always MJPEG is used.
If there indeed is an option to stream "cycle" as MPEG, please tell me where it is - I couldn't find it in the manual.
cordel
Post by cordel »
:lol:
I forgot that feature was broken in the source :oops:
I have the patch some where, just a question of where :?:
Should be posted the file to patch would be html_view_cycle.php
[edit] I searched the forum and it's MIA, I know we had some database problems around the same time and it must have affected that post along with a lot of other missing posts from that period. I still have around 80 Gigs of data to dig through so I'll try to find it and repost it. Can't say exactly when though.
mangoo
Post by mangoo »
cordel wrote::lol:
OK, thanks anyway.
Will ping this thread in a couple of days to remind you (if you still can't find it).
cordel
Post by cordel »
:lol: 80 gigs, you be lucky to see it in a month. Not all the drives have even been loaded on the new machine yet. A search didn't turn up anything either but that don't mean I remember what I named it :shock:
