Hi all... I'm getting an error on one of my dvr's that goes something like this:
Jul 19 03:40:31 video zma_m3[25536]: INF [Front_Parking: 1115837 - Gone into alert state]
Jul 19 03:40:33 video kernel: bttv3: OCERR @ 36cf7014,bits: HSYNC OFLOW FBUS OCERR*
Jul 19 12:08:31 video syslogd 1.4.1: restart.
The restart is manual. It hard locks the system.
System Crashes; Log Included
- captain_morgan
First I would check the input for the device, try hooking the cam up (or another cam) to Video3 and see if the possible sync issue goes away. If that don't give ya any joy, check for a new kernel (shame on you for not providing your Distro/Release and no dmesg output for bttv, or Info on the card you have installed
). Else you might have to give a shot at a different Distro and see if some one else might have inclused a patch to this problem in their kernel.
- captain_morgan
Thanks for the response...
Now that you mention it, I've been having trouble with that input. The camera keeps loosing signal, intermittently. I just figured it was the camera. I wonder if it's the card? I'll try putting the camera on another input and see if the signal breaks continue. Thanks Corey.
No Problem. I should have better clarified though that what I was getting at was not the camera, but the feed line. If it's a long run it might be picking up noise from AC lines or something in that nature. So by hooking the cam right to the back of the card would verify the cam is good and you have a feed problem, or look at the cam vs the input.
Morgan are you using an ebay type 8 chip capture card AKA 8800 card by any chance? I'm having the same problem as you. I'm using Ubuntu 6.06 64bit and the crash could happen in as little as 1 hour or as long as 2 days. I'm comming to the conclusuion that the card has crashed and the kernel is waiting for some handshaking that never comes. Even if there is a patch it wouldnt help with the crashed card which requires a reboot.
This could be heat related as it seems to be happening more in the summer and those chips get too hot.
- captain_morgan
Blue Cherry has good stuff and good service. But the heat on ProVideo cards is quite high. We had quite a few behave flaky with LuxRiot. They tried all kinds of hardware swaps, and all would fail about a month later. But heat sinks worked! Something else to consider is http://www.zalman.co.kr/usa/product/vie ... 5&code=016 with multi card systems.
