8 channel 240 FPS card on EBAY...almost working
Posted: Tue Aug 07, 2007 1:54 am
Okay everyone, I am in need of some of your help.
Some of you have gotten this card to work, and am hoping with your guidance I can get mine to work as well. I have tried everything I can think of but am still getting blue screens with it, which is good, but bad....
Here's the story. I took a running FC6 system with a single chip 4-port card (card=77) that was working perfectly fine and switched to an 8 port, 8 chip, 240fps card I bought on EBay, I mentioned in a previous post.
The original setup was working flawlessly, and the original card was $6 from EBay and was a BT878 based Chinese special.
I did the card swap after building a 2nd machine with FC7 and following the how-to guide and ending up with blue screens. I thought "hey, take a setup that is known to work and change the modprobe.conf around a little big and boom!" Bzzzzztttt wrong answer....
I have tried tuner=4, radio=-1, gbuffers-16, card=102......, card=77......, card=0, etc., etc,etc.
Please help a brother out...I am no Linux guru, but a slight dabbler for years.
Here is a link to what that card looks like
http://www.braeckel.com/Gallery/main.php?g2_itemId=173
Here is a dmesg dump from the system with all card related options commented out:
Here is a scanpci dump from the system:
My booting does hang for a while, like what others have posted, but I didn't see that the i2c stuff did much for me....
Any help you guys can offer would be amazingly appreciated!
Thanks,
Doug
Linux video capture interface: v2.00
input: PC Speaker as /class/input/input2
hdc: ATAPI 48X DVD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
bttv: driver version 0.9.16 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
ACPI: PCI Interrupt 0000:03:08.0[A] -> GSI 21 (level, low) -> IRQ 201
bttv0: Bt878 (rev 17) at 0000:03:08.0, irq: 201, latency: 32, mmio: 0xf85fe000
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
ACPI: PCI Interrupt 0000:00: 1f.3[B] -> GSI 17 (level, low) -> IRQ 209
e100: Intel(R) PRO/100 Network Driver, 3.5.10-k2-NAPI
e100: Copyright(c) 1999-2005 Intel Corporation
ACPI: PCI Interrupt 0000:00:1f.5[B] -> GSI 17 (level, low) -> IRQ 209
PCI: Setting latency timer of device 0000:00:1f.5 to 64
intel8x0_measure_ac97_clock: measured 58128 usecs
intel8x0: clocking to 48000
tveeprom 0-0050: Huh, no eeprom present (err=-121)?
bttv0: using tuner=-1
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: i2c: checking for TDA9887 @ 0x86... not found
bttv0: registered device video0
bttv0: registered device vbi0
ACPI: PCI Interrupt 0000:02:08.0[A] -> GSI 20 (level, low) -> IRQ 217
e100: eth0: e100_probe: addr 0xfeaff000, irq 217, MAC addr 00:07:E9:E6:D5:94
bttv: Bt8xx card found (1).
ACPI: PCI Interrupt 0000:03:09.0[A] -> GSI 22 (level, low) -> IRQ 225
bttv1: Bt878 (rev 17) at 0000:03:09.0, irq: 225, latency: 32, mmio: 0xf85fc000
bttv1: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
tveeprom 2-0050: Huh, no eeprom present (err=-121)?
bttv1: using tuner=-1
bttv1: i2c: checking for MSP34xx @ 0x80... not found
bttv1: i2c: checking for TDA9875 @ 0xb0... not found
bttv1: i2c: checking for TDA7432 @ 0x8a... not found
bttv1: i2c: checking for TDA9887 @ 0x86... not found
bttv1: registered device video1
bttv1: registered device vbi1
bttv: Bt8xx card found (2).
ACPI: PCI Interrupt 0000:03: 0a.0[A] -> GSI 23 (level, low) -> IRQ 193
bttv2: Bt878 (rev 17) at 0000:03:0a.0, irq: 193, latency: 32, mmio: 0xf85fa000
bttv2: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
tveeprom 3-0050: Huh, no eeprom present (err=-121)?
bttv2: using tuner=-1
bttv2: i2c: checking for MSP34xx @ 0x80... not found
bttv2: i2c: checking for TDA9875 @ 0xb0... not found
bttv2: i2c: checking for TDA7432 @ 0x8a... not found
bttv2: i2c: checking for TDA9887 @ 0x86... not found
bttv2: registered device video2
bttv2: registered device vbi2
bttv: Bt8xx card found (3).
ACPI: PCI Interrupt 0000:03:0b.0[A] -> GSI 20 (level, low) -> IRQ 217
bttv3: Bt878 (rev 17) at 0000:03:0b.0, irq: 217, latency: 32, mmio: 0xf85f8000
bttv3: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
tveeprom 4-0050: Huh, no eeprom present (err=-121)?
bttv3: using tuner=-1
bttv3: i2c: checking for MSP34xx @ 0x80... not found
bttv3: i2c: checking for TDA9875 @ 0xb0... not found
bttv3: i2c: checking for TDA7432 @ 0x8a... not found
bttv3: i2c: checking for TDA9887 @ 0x86... not found
bttv3: registered device video3
bttv3: registered device vbi3
bttv: Bt8xx card found (4).
ACPI: PCI Interrupt 0000:03:0c.0[A] -> GSI 21 (level, low) -> IRQ 201
bttv4: Bt878 (rev 17) at 0000:03:0c.0, irq: 201, latency: 32, mmio: 0xf85f6000
bttv4: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv4: gpio: en=00000000, out=00000000 in=00ffffff [init]
tveeprom 5-0050: Huh, no eeprom present (err=-121)?
bttv4: using tuner=-1
bttv4: i2c: checking for MSP34xx @ 0x80... not found
bttv4: i2c: checking for TDA9875 @ 0xb0... not found
bttv4: i2c: checking for TDA7432 @ 0x8a... <6>Intel 82802 RNG detected
floppy0: no floppy controllers found
not found
bttv4: i2c: checking for TDA9887 @ 0x86... not found
bttv4: registered device video4
bttv4: registered device vbi4
lp: driver loaded but no devices found
bttv: Bt8xx card found (5).
ACPI: PCI Interrupt 0000:03:0d.0[A] -> GSI 22 (level, low) -> IRQ 225
bttv5: Bt878 (rev 17) at 0000:03:0d.0, irq: 225, latency: 32, mmio: 0xf85f4000
bttv5: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv5: gpio: en=00000000, out=00000000 in=00ffffff [init]
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
IPv6 over IPv4 tunneling driver
ACPI: Power Button (FF) [PWRF]
ACPI: Sleep Button (CM) [SLPB]
tveeprom 6-0050: Huh, no eeprom present (err=-121)?
bttv5: using tuner=-1
bttv5: i2c: checking for MSP34xx @ 0x80... <6>md: Autodetecting RAID arrays.
md: autorun ...
md: ... autorun DONE.
device-mapper: multipath: version 1.0.4 loaded
EXT3 FS on dm-0, internal journal
kjournald starting. Commit interval 5 seconds
EXT3 FS on hda1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
not found
bttv5: i2c: checking for TDA9875 @ 0xb0... not found
bttv5: i2c: checking for TDA7432 @ 0x8a... <6>Adding 2031608k swap on /dev/VolGroup00/LogVol01. Priority:-1 extents:1 across:2031608k
not found
bttv5: i2c: checking for TDA9887 @ 0x86... ip_tables: (C) 2000-2006 Netfilter Core Team
Netfilter messages via NETLINK v0.30.
ip_conntrack version 2.4 (8186 buckets, 65488 max) - 228 bytes per conntrack
not found
bttv5: registered device video5
bttv5: registered device vbi5
bttv: Bt8xx card found (6).
ACPI: PCI Interrupt 0000:03:0e.0[A] -> GSI 23 (level, low) -> IRQ 193
bttv6: Bt878 (rev 17) at 0000:03: 0e.0, irq: 193, latency: 32, mmio: 0xf85f2000
bttv6: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv6: gpio: en=00000000, out=00000000 in=00ffffff [init]
process `sysctl' is using deprecated sysctl (syscall) net.ipv6.neigh.lo.base_reachable_time; Use net.ipv6.neigh.lo.base_reachable_time_ms instead.
ADDRCONF(NETDEV_UP): eth0: link is not ready
e100: eth0: e100_watchdog: link up, 100Mbps, full-duplex
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
tveeprom 7-0050: Huh, no eeprom present (err=-121)?
bttv6: using tuner=-1
bttv6: i2c: checking for MSP34xx @ 0x80... not found
bttv6: i2c: checking for TDA9875 @ 0xb0... <7>eth0: no IPv6 routers present
not found
bttv6: i2c: checking for TDA7432 @ 0x8a... not found
bttv6: i2c: checking for TDA9887 @ 0x86... not found
bttv6: registered device video6
bttv6: registered device vbi6
bttv: Bt8xx card found (7).
ACPI: PCI Interrupt 0000:03:0f.0[A] -> GSI 20 (level, low) -> IRQ 217
bttv7: Bt878 (rev 17) at 0000:03:0f.0, irq: 217, latency: 32, mmio: 0xf85f0000
bttv7: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv7: gpio: en=00000000, out=00000000 in=00ffffff [init]
Bluetooth: Core ver 2.10
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP ver 2.8
Bluetooth: L2CAP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.1
tveeprom 8-0050: Huh, no eeprom present (err=-121)?
bttv7: using tuner=-1
bttv7: i2c: checking for MSP34xx @ 0x80... not found
bttv7: i2c: checking for TDA9875 @ 0xb0... not found
bttv7: i2c: checking for TDA7432 @ 0x8a... not found
bttv7: i2c: checking for TDA9887 @ 0x86... not found
bttv7: registered device video7
bttv7: registered device vbi7
bt878: AUDIO driver version 0.0.0 loaded
bt878: Bt878 AUDIO function found (0).
ACPI: PCI Interrupt 0000:03:08.1[A] -> GSI 21 (level, low) -> IRQ 201
bt878_probe: card id=[0x0],[ <NULL> ] has DVB functions.
bt878(0): Bt878 (rev 17) at 03:08.1, irq: 201, latency: 32, memory: 0xf85ff000
bt878: Bt878 AUDIO function found (1).
ACPI: PCI Interrupt 0000:03:09.1[A] -> GSI 22 (level, low) -> IRQ 225
bt878(1): Bt878 (rev 17) at 03:09.1, irq: 225, latency: 32, memory: 0xf85fd000
bt878: Bt878 AUDIO function found (2).
ACPI: PCI Interrupt 0000:03:0a.1[A] -> GSI 23 (level, low) -> IRQ 193
bt878(2): Bt878 (rev 17) at 03:0a.1, irq: 193, latency: 32, memory: 0xf85fb000
bt878: Bt878 AUDIO function found (3).
ACPI: PCI Interrupt 0000:03:0b.1[A] -> GSI 20 (level, low) -> IRQ 217
bt878(3): Bt878 (rev 17) at 03:0b.1, irq: 217, latency: 32, memory: 0xf85f9000
bt878: Bt878 AUDIO function found (4).
bt878: Too many devices inserted
ACPI: PCI interrupt for device 0000:03:0c.1 disabled
bt878: probe of 0000:03: 0c.1 failed with error -12
ACPI: PCI interrupt for device 0000:03:0d.1 disabled
bt878: probe of 0000:03:0d.1 failed with error -12
ACPI: PCI interrupt for device 0000:03:0e.1 disabled
bt878: probe of 0000:03:0e.1 failed with error -12
ACPI: PCI interrupt for device 0000:03:0f.1 disabled
bt878: probe of 0000:03:0f.1 failed with error -12
pci bus 0x0003 cardnum 0x08 function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
STATUS 0x0290 COMMAND 0x0106
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xf85fe008 addr 0xf85fe000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0003 cardnum 0x08 function 0x01: vendor 0x109e device 0x0878
Brooktree Corporation Bt878 Audio Capture
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xf85ff008 addr 0xf85ff000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0003 cardnum 0x09 function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85fc008 addr 0xf85fc000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x09 function 0x01: vendor 0x109e device 0x0878
BASE0 0xf85fd008 addr 0xf85fd000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0a function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85fa008 addr 0xf85fa000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0003 cardnum 0x0a function 0x01: vendor 0x109e device 0x0878
BASE0 0xf85fb008 addr 0xf85fb000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0a
pci bus 0x0003 cardnum 0x0b function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85f8008 addr 0xf85f8000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x07
pci bus 0x0003 cardnum 0x0b function 0x01: vendor 0x109e device 0x0878
BASE0 0xf85f9008 addr 0xf85f9000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x07
pci bus 0x0003 cardnum 0x0c function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85f6008 addr 0xf85f6000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0c function 0x01: vendor 0x109e device 0x0878
STATUS 0x0290 COMMAND 0x0100
BASE0 0xf85f7008 addr 0xf85f7000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0d function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85f4008 addr 0xf85f4000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0d function 0x01: vendor 0x109e device 0x0878
BASE0 0xf85f5008 addr 0xf85f5000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0e function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85f2008 addr 0xf85f2000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0e function 0x01: vendor 0x109e device 0x0878
BASE0 0xf85f3008 addr 0xf85f3000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0f function 0x00: vendor 0x109e device 0x036e
BASE0 0xf85f0008 addr 0xf85f0000 MEM PREFETCHABLE
pci bus 0x0003 cardnum 0x0f function 0x01: vendor 0x109e device 0x0878
BASE0 0xf85f1008 addr 0xf85f1000 MEM PREFETCHABLE
Thanks,
Doug
