No errors, no video, blank black screens (Solved!!!)
Blank black screen showing time and date. No errors that I can tell in the logs. Any help?
ZoneMinder 1.22.3
Gentoo 2007.0
emerge zoneminder (not from source)
PV-155 16 port (from bluecherry)
Logs below:
zmaudit.log
zmdc.log
08/09/07 18:50:34.137652 zmdc[9088].INF [Server starting at 07/08/09 18:50:34]
08/09/07 18:50:37.326450 zmdc[9088].INF ['zmfilter.pl' starting at 07/08/09 18:50:37, pid = 9111]
08/09/07 18:50:37.726452 zmdc[9088].INF ['zmaudit.pl -c' starting at 07/08/09 18:50:37, pid = 9116]
08/09/07 18:50:38.066350 zmdc[9088].INF ['zmwatch.pl' starting at 07/08/09 18:50:38, pid = 9121]
08/09/07 18:50:38.398367 zmdc[9088].INF ['zmupdate.pl -c' starting at 07/08/09 18:50:38, pid = 9125]
08/09/07 18:50:38.809844 zmdc[9088].WAR [Can't find process with command of 'zma -m']
08/09/07 18:50:38.975730 zmdc[9088].WAR [Can't find process with command of 'zmc -m']
08/09/07 18:52:22.396303 zmdc[9088].WAR [Can't find process with command of 'zmc -d /dev/video0']
08/09/07 18:52:22.565234 zmdc[9088].INF ['zmc -d /dev/video0' starting at 07/08/09 18:52:22, pid = 9160]
08/09/07 18:52:22.780765 zmdc[9088].WAR [Can't find process with command of 'zma -m 7']
08/09/07 18:52:22.996027 zmdc[9088].WAR [Can't find process with command of 'zma -m']
08/09/07 18:52:23.168867 zmdc[9088].WAR [Can't find process with command of 'zmc -m']
zmfilter.log
08/09/07 18:50:37.562667 zmfilter[9111].INF [Scanning for events]
08/09/07 18:50:42.566472 zmfilter[9111].DBG [Reloading filters]
08/09/07 18:50:42.567316 zmfilter[9111].DBG [Sleeping for 60 seconds]
08/09/07 18:51:42.570439 zmfilter[9111].DBG [Sleeping for 60 seconds]
08/09/07 18:52:42.574353 zmfilter[9111].DBG [Sleeping for 60 seconds]
zmpkg.log
08/09/07 18:50:33.782183 zmpkg[9076].INF [Command: start]
zmupdate.log
zmwatch.log
08/09/07 18:50:38.218920 zmwatch[9121].INF [Watchdog starting]
08/09/07 18:50:38.219439 zmwatch[9121].INF [Watchdog pausing for 30 seconds]
==> messages <==
Aug 9 18:52:22 localhost zmdc[9088]: WAR [Can't find process with command of 'zmc -d /dev/video0']
Aug 9 18:52:22 localhost zmdc[9088]: INF ['zmc -d /dev/video0' starting at 07/08/09 18:52:22, pid = 9160]
Aug 9 18:52:22 localhost zmdc[9160]: INF ['zmc -d /dev/video0' started at 07/08/09 18:52:22]
Aug 9 18:52:22 localhost zmc_dvideo0[9160]: INF [Debug Level = 0, Debug Log = <none>]
Aug 9 18:52:22 localhost zmc_dvideo0[9160]: INF [Starting Capture]
Aug 9 18:52:22 localhost zmdc[9088]: WAR [Can't find process with command of 'zma -m 7']
Aug 9 18:52:22 localhost zmdc[9088]: WAR [Can't find process with command of 'zma -m']
Aug 9 18:52:23 localhost zmdc[9088]: WAR [Can't find process with command of 'zmc -m']
Aug 9 18:53:29 localhost zmc_dvideo0[9160]: INF [New: 1000 - Capturing at 14.93 fps]
Aug 9 18:54:36 localhost zmc_dvideo0[9160]: INF [New: 2000 - Capturing at 14.93 fps]
Aug 9 18:55:42 localhost zmc_dvideo0[9160]: INF [New: 3000 - Capturing at 15.15 fps]
Aug 9 18:56:49 localhost zmc_dvideo0[9160]: INF [New: 4000 - Capturing at 14.93 fps]
Any ideas?
ZoneMinder 1.22.3
Gentoo 2007.0
Logs below:
zmaudit.log
zmdc.log
zmfilter.log
zmpkg.log
zmupdate.log
zmwatch.log
==> messages <==
Any ideas?
have you set your card type? and whats your messages log say
James Wilson
just seen that and as its capturing that seems odd. Can you playback anything?
James Wilson
A quick search turned up this:
http://www.zoneminder.com/forums/viewto ... ight=pv155
dmesg|grep bttvcordel wrote:An output from:
dmesg |grep bttv
Should answer a few questions.
bttv: driver version 0.9.17 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:04:08.0, irq: 18, latency: 132, mmio: 0xf8000000
bttv0: detected: Provideo PV150A-1 [card=98], PCI subsystem ID is aa00:1460
bttv0: using: ProVideo PV150 [card=98,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: registered device video0
bttv0: registered device vbi0
bttv0: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (1).
bttv1: Bt878 (rev 17) at 0000:04:09.0, irq: 19, latency: 132, mmio: 0xf8002000
bttv1: detected: Provideo PV150A-2 [card=98], PCI subsystem ID is aa01:1461
bttv1: using: ProVideo PV150 [card=98,autodetected]
bttv1: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv1: using tuner=-1
bttv1: registered device video1
bttv1: registered device vbi1
bttv1: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (2).
bttv2: Bt878 (rev 17) at 0000:04:0a.0, irq: 20, latency: 132, mmio: 0xf8004000
bttv2: detected: Provideo PV150A-3 [card=98], PCI subsystem ID is aa02:1462
bttv2: using: ProVideo PV150 [card=98,autodetected]
bttv2: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv2: using tuner=-1
bttv2: registered device video2
bttv2: registered device vbi2
bttv2: PLL: 28636363 => 35468950 .. ok
bttv: Bt8xx card found (3).
bttv3: Bt878 (rev 17) at 0000:04:0b.0, irq: 17, latency: 132, mmio: 0xf8006000
bttv3: detected: Provideo PV150A-4 [card=98], PCI subsystem ID is aa03:1463
bttv3: using: ProVideo PV150 [card=98,autodetected]
bttv3: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv3: using tuner=-1
bttv3: registered device video3
bttv3: registered device vbi3
bttv3: PLL: 28636363 => 35468950 .. ok
bttv0: PLL can sleep, using XTAL (28636363).
The last two lines there repeated about 200 times. I cut them off just to shorten the post.
Matt
I'm having that problem too but in his post he says the first channels work fine where mine don't. PAL gets me an image but NTSC does not.cordel wrote:A quick search turned up this:
Matt
I used the module options to fix that other problem but I'm still having the PAL/NTSC issue.mpoertner wrote:I'm having that problem too but in his post he says the first channels work fine where mine don't. PAL gets me an image but NTSC does not.cordel wrote:A quick search turned up this:
Matt
Any more ideas? I feel so close to having a working system here. Any help would be greatly appreciated!
Cheers!
Matt
Are you guys perhaps using a 2.6.21.5 kernel on your distribution? I was on my Slack12 installation and found that a bug was introduced in the bttv driver in this version. Check my post on the subject:
http://www.zoneminder.com/forums/viewtopic.php?t=10108
I had similar symtoms where PAL would show a fuzzy picture but nothing with NTSC. I managed to get it working once by unloading then reloading the bttv driver then running TVTime to init the driver. Once the machine was rebooted I couldn't get it to work again, and I had forgotten what I did before to get it working.
Try this test:
stop zm:
zmpkg.pl stop
unload the bttv driver:
rmmod bttv
reload the bttv driver:
modprobe bttv
run tvtime to init the driver (if you have it installed)
tvtime -d /dev/video0
(change /dev/video0 to whatever your device is)
exit tvtime
Then try starting zm and see if you get a picture in NTSC. If you get a picture then you are probably experiencing the kernel bug that I was.
Try this test:
stop zm:
zmpkg.pl stop
rmmod bttv
modprobe bttv
exit tvtime
I use bttv on a debian system, dmesg shows this.
bttv: driver version 0.9.15 loaded
bttv0: Bt878 (rev 17) at 0000:00:0a.0, irq: 169, latency: 32, mmio: 0xde009000
bttv0: using: *** UNKNOWN/GENERIC *** [card=0,autodetected]
bttv0: gpio: en=00000000, out=00000000 in=00f360ff [init]
bttv: readee error
bttv0: i2c: checking for MSP34xx @ 0x80... not found
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
If i remember correctly (this was configured 18 months ago) i had to use the device Format as Auto, and capture pallette as RGB24, anything else gave a similar display to what you describe.
If you use a different channel, do you get a blue screen ?.
Is your camera working correctly ?
Have you tried forcing a generic card, (when using modprobe)?.
bttv: readee error
Yup, it was the Kernel!!!! I downloaded and configured 2.6.23 (Gentoo mm-sources) and now I get a clear picture.overly wrote:Are you guys perhaps using a 2.6.21.5 kernel on your distribution? I was on my Slack12 installation and found that a bug was introduced in the bttv driver in this version.
Thanks a TON overly!
Matt
